08-15 blade Samco hoses and samco clips set in blue with extra rad pipes and over flows and breathers etc SOLD 08-15 Hrc Ali bell mouths ( massive power gains ) SOLD 08-12 radiator with mesh to prevent stone chips SOLD (fits 12-15 but needs a different hose ) 08-15 k&n SOLDĀ£32.50 All prices are posted
Am I right in saying these are the same spec on OE 2014 model? Except mine are plastic! They sure do look the same....
They are a simular design . Middle 2 are slightly taller which helps with torque . It's more to do with the materials and finish. The Ali Hrc ones are abrasive inside to grip the air and force it in to the head . It's like ram air so increases air flow like porting the head . I got nearly 3 brake more just from the bell mouths so not to shabby . I could be wrong tho so hopefully someone will correct me if I am
i need something like this in my head. get some ponies back would these be hard to make for a group buy maybe
No point really in buying them if you ain't going to get it tuned to suit and get the most out of your buy.
Yeh the taller stacks are on the outside and lower ones in the middle on 14 and SP models, not sure about early years....
