Hi, I have for sale a HRC 1/6th turn throttle tube brand new and in packet. Normally use with kit housing and cables but can be made to work with standard items with little effort. £21 posted. Thanks
Is it the same like this http://www.ebay.co.uk/itm/170883856703?_trksid=p2060353.m1438.l2649&ssPageName=STRK:MEBIDX:IT What I need to do to work with standard housing and standard cables
yes it's the same. Basically the cables are tough to fit as they are a bit short. you also need to shim each side of the cam on throttle tube as it's a bit slack in the housing. for this I cut 2 discs out of a white plastic de-ionised water bottle. It works a treat.
