Cast Iron Welding
Discussion in 'Lounge' started by N2OCapri, Jan 11, 2016.
  1. N2OCapri
    N2OCapri Active Member
    Has anyone here ever had or used a specialist cast iron welder ? I need a bracket stitching back together and would value recommendation :)
  2. pete954
    pete954 Active Member
    If its just a bracket you may have an easier time brazing it which is what I do unless it's a pressure or heavy load bearing bit of kit.
  3. racman
    racman Active Member
    pe heat the job in an oven, and v prep it. use a sinus rod and stick weld. piece of piss
  4. Stevie_d
    Stevie_d Senior Member
    Didn't think cast iron could be welded or it would crack ?
  5. Stevie_d
  6. N2OCapri
    Apparently has to be preheated and then cooled slowly, got a local welder friend of a friend that comes highly recommended to do it :)
  7. racman
    thats why you pre heat it and use the correct sinus filler rod
  8. Geoff Paxton
    Geoff Paxton Member
    Very difficult to do properly, it is never as strong as before as it is usually weakened at either side of the weld area. Can be done though by someone who knows what they are doing.
  9. t0m541
    t0m541 Senior Member
    It can be done,
