Reading fault codes?
Discussion in 'Maintenance' started by jamesm09, Jan 18, 2016.
  1. jamesm09
    jamesm09 Senior Member
    Hi all. I've removed the alarm from my 2006 blade and I'm getting the FI light on now.
    How do I read the fault memory? The bike starts and runs on.
    Cheers!
  2. sps170373
    It will be a series of flashes which correspond with the fault in the manual
  3. scooby
    scooby Elite Member
    you need to bridge 2 points on the diagnostic plug,then read the flashes,they will be long+short.
    long=10
    short=1
    then add them up and look in your workshop manual what it corresponds to.you can clear the failt memory aswell,sometimes it's easier to this 1st,then run the bike and do a check as it will have logged various faults along the way,so can be trcky to work out what the actual issue is now.
    I assume you have a download of the manual,it explains it all uin the there,how to read them,how to clear them,and table of faults.
  4. jamesm09
    Cheers guys!
    No I've not got a manual for it scooby.
  5. Barstewardsquad
    If it does it all the time you can get the code by putting the side stand down whilst the light is on with the engine running.
  6. scooby
    scooby Elite Member
    well download one,they are free,there will be a link on here somewhere
  7. sps170373
  8. jamesm09
    Got one about half hour ago. Thanks!
  9. jamesm09
    I'll try it tomorrow night because I snapped a bolt on the rocker cover. Trying to fit some blanking plates:mad:
  10. sinewave
    Snapped a Bolt?
    Pah!
    Fort U waz a highly skilled Muckanik?
  11. jamesm09
    If it's seized, it's seized!:D
    If I snapped it tightening the bolt, you have a valid point;)
