Carbon Fiber Rear Hugger Suggestions
Discussion in 'General 1000RR Discussion' started by RR_mike, Jan 29, 2016.
  1. RR_mike
    RR_mike New Member
    Anyone got any suggestions for a good rear hugger in carbon fiber or similar finish? Seen a couple on ebay but the prices are a little ridiculous...
    Pics of your own and/or links to some for sale would be awesome.Thanks
  2. F1CT1C10U5
    F1CT1C10U5 Well-Known Member
    This is mine. Same look as the OEM Honda Racing one, without "Honda Racing" sticker. I eventually got the Honda Racing vinyl sticker and placed it there:
    You can see more pics here:
    https://www.facebook.com/photo.php?...91586271.13414.100000357521023&type=3&theater
    Got it here:
    http://www.ebay.com/itm/Carbon-Rear...450218?hash=item3f5637ffea:g:giUAAMXQlgtS3h1r
    Couple of notes:
    1- This is for non-ABS only
    2- That seller also sells the front carbon fiber fender. I don't recommend it, as it's too thin, deforms at high speeds and rubs the tire. I still got mine tho, after it's been fixed and re-enforced.
  3. sps170373
    King carbon as will fit both abs and non abs bikes
  4. F1CT1C10U5
    The problem with the ABS version is that it has a lot less clearance, it's not a problem of fitting, it's a problem of clearance. You risk hitting a bump on the road and have your hugger broken to pieces. That's why Honda itself only sells the hugger to non-ABS version only.
    BTW, I've owned the King Carbon hugger prior to having the current one. It has one major flaw (at least in my book). On of the sides was higher than the other, so it gave the bike an odd look. Also aesthetically is not as good looking as the OEM (or OEM like) one, but that's a matter of taste.
    EDIT: What I said about clearance was true for the 08-11 model. Don't know if something changed on the 12+ version.
    #4 F1CT1C10U5, Jan 29, 2016
  5. Nigelg79
    Nigelg79 Active Member
  6. neil.marsh.758
    neil.marsh.758 New Member
    Ive just bought an OEM rear hugger on Wednesday. Contacted the Dealer for the colour codes as its the BSB replica. Unfortunately they don't know. Emailed Honda UK several times and they don't know either. Expected a bit more from Honda.
  7. tuktuk
    tuktuk Elite Member
    ProFiber GP
  8. tuktuk
    tuktuk Elite Member
  9. RR_mike
    RR_mike New Member
    Thanks for all the suggestions guys, looking good.
  10. RR_mike
    RR_mike New Member
    One last question...All these huggers listed for 08-11 etc should all fit fine for the 12-15 models? anybody aware of any small changes to the fitment?
  11. sps170373
    Perhaps yours was a one off as mine isn't one sided and have no clearance problems
  12. 1000rr73
    1000rr73 Active Member
    They won't fit without adjustment. You need to dremel or cut out a 2 inch square beneath where rear shock sits.
  13. beavis
    beavis Active Member
    Had a Powerbronze on my 09 and a Honda Racing on my 20th anniversary and the difference in quality is night and day. HR is worth the extra, PB was ok when new but after a bit looked cheap and nasty.
  14. derchef
    derchef Well-Known Member
    That s HUGE , there are really little and nice out in ebay....
  15. F1CT1C10U5
    Yup... but that's the one I like best. ;)
  16. derchef
    de gustibus....
  17. Manfred
    Manfred Active Member
    Harris hugger 08-11 with small modification for the 2012 shock. Much smaller than most of the others, but looks tidy.
