Cleaned up the Yoshi R77
Discussion in 'Maintenance' started by Suttz83, Feb 7, 2016.
  1. Suttz83
    Suttz83 Active Member
    Got a Dremel for a Christmas present so thought I'd put it to use. I'm a bit of a clean freak and the Yoshimura r77 wasn't up to my standards when I bought the bike so thought as I'm stripping a few bits off the bike to clean it up I thought I'd get the Dremel out and set about it.
    I'm happy with how it turned out. Looks a lot better I think. Thought I'd share a picture with you all.
    Before and after;
    Now for the rest of the bike.
    • Like Like x 6
  2. raphael
    That's some going with a small dremel , but looks good mate
  3. Slick
    good work, mine's covered in acf50 right now as is grubby as feck.
    Not gonna touch it till the spring! Notice yours has the baffle bolt on the outside, mine is between the swing arm and sleeve, bit of a ball-ache when I need to fit the baffle:mad:
  4. Glb
    Glb Active Member
    What products and tools did you use?
  5. Dave
    Dave Member
    Cracking job, pity it'll be back to the discoloured look when run for any length of time:(
  6. Jandy
    Jandy Active Member
    All you need to do now is put it up for sale on the forum ;););)
  7. Suttz83
    It'll stay clean. I clean my bikes more than I ride them!
    I cleaned it first with some warm water and Brillo pads. After that I used a Dremal with polishing attachments and Autosol metal polish. Takes a bit of time but the rewards are good.
  8. Mr OCD
    Mr OCD Well-Known Member
    Lovely work but as mentioned it will not stay silver. It is stainless therefore will go brown very quickly ... Have a look at the downpipes on your bike for example.
  9. Cbrjay
    Cbrjay Well-Known Member
  10. Suttz83
    I'll just keep taking it off and buffing it up again !!
    Cbrjay- that's basically the same attachment I used but smaller for the Dremal.
