Improving the man cave
Discussion in 'Lounge' started by martinowen, Feb 14, 2016.
  1. martinowen
    As my kids are getting older their toys are getting bigger and more of them so my man cave has become less of my area and more of a dumping ground for everyone's shite with a letter box opening for my bike to slide in!
    So I'm building a little Worksop area and storage for the crap to make the place more mine again, still a work in progress, have some wall cabinets etc to go on yet and a big tool box to slot in there yet
    • Like Like x 9
  2. dessp2
    dessp2 Well-Known Member
    Looks great Martin. Liking the bottle of beer on the go on the work surface, you can't spend time in the man cave without the compulsory beer in your hand and radio on the go.
  3. sinewave
    Tut Tut Tut Martin! :eek:
    Yee cannee go wiring sockets up like that!
  4. raphael
    thing is martin, will you beable to get to it when all the crap gets put back in?
  5. thezipsteruk
    thezipsteruk Elite Member
    I envy anyone with a man cave so wire your sockets any way you like lol
  6. martinowen
    Lol I done loads of sockets in there like that
  7. martinowen
    Oh yes beer fridge plugged in today :D
  8. SimonRR
    SimonRR God Like
    I wont put a picture of mine up, I dont you OCD lots having heart attacks ;) :D
  9. sinewave
    Hope U have a good Fire Extinguisher? ;)
  10. martinowen
    Is it that bad? I fitted them about 5 years ago no issues yet :eek:
    What did I miss
  11. sinewave
    Lol!
    You'll be fine matey as long as you don't go plugging in too much load for too long!
    (Boring Bit!)
    The first and original socket on that pic is part of a 'Ring Circuit' (most prob) and is fused at 30/32 amps.
    2.5mm T/E cable which is used in the pic and is pretty much standard fare for domestic socket circuits starts to melt at prolonged periods of load much above 24amps which can lead Fire and fecked cabling.
    It's only allowed to be used on a Ring Circuit because the load is split roughly equally round the circuit so no part of the cable is subjected to the max loading of 32A.
    When you've added (spurred) off the original socket you've now created a 'radial' circuit off a 'Ring circuit'
    One of these is OK and permitted within the Regs as the load cannot exceed one sockets worth.
    In your case you have multiple sockets on this spurred radial which thus lead to 'Meltdown' should you or others plug in Heaters etc.
    A radial circuit should be fused at 20A max
    Here endeth the Sermon!
  12. martinowen
    I might get it checked out just to be safe lol
  13. gringo
    gringo Active Member
    Get one of these this in my cave
  14. Glb
    Glb Active Member
    2.5t+e is rated at 27amp ref method C.
  15. Slimwilly
    Slimwilly Member
    my whole garage is on an extension cable, ooh, tumble dryer in there.freezer, and then sockets for welder etc, note only one at a time
  16. martinowen
    Yea I have a few bits plugged in :eek:
  17. sinewave
    Extension lead will not overload and melt as it's got a 13A Fuse in the Plug Top.
  18. racman
    racman Active Member
    thats a feckin good idea
  19. Muffking
    Keep ém coming Martin as i'm moving house in a couple of months and will be looking for ideas for a black canvas.
    I'll be looking to do up a single attached breeze block garage. Luckily mine has the consumer unit for the house, so I'll probably get a ring for the garage added. And if the wife gets her way with a new kitchen (which she probably will) then I'll have the old units for the garage.
  20. martinowen
    Exactly what's happened here, she gets a new kitchen I get the old one to play with
    Sinewave my fuse box is in the garage, my sockets start from there, does that make it ok or is that worse? lol
