Arrow Trophy Titanium Headers
Discussion in 'Mods, Upgrades, Accessories and Products' started by TW4T50N, Feb 22, 2016.
  1. TW4T50N
    TW4T50N Active Member
    So I've stumbled across a set of titanium headers and thought about replacing my standard headers and Taylormade exhaust with a full titanium system with Racefit.
    Does anyone know how different the Arrow headers are in comparison to the standard headers? Not sure if the angle at the collector exit or fittings vary slightly meaning the Racefit will need rebending or modifying?
    Cheers!
  2. foenix
    foenix Active Member
    I have had a set on my Blade, the 54mm ( the bigger ) ones, very good perf with the proper tune.
  3. TW4T50N
    Are you running the full system or just the headers/collector/link pipe? If it's just parts of the system, did you have any trouble fitting a different end can to the rest of the system? :)
    It'll be going for a full remap once the system is fitted as it's currently set up for stock headers and Taylormade :)
  4. foenix
    I ve ride it with its Trophy can, and an Akra carbon can from a full system, at the moment of the inlet diameter is good, you can mount everything.
  5. TW4T50N
    Great, you had no issues fixing another make onto the full system then?
    Got any photos of it fitted with the Akra at all? Don't wanna spend the money and find out a Racefit won't fit onto the rest of the system. They can modify the diameter no problem.
  6. Waynenorris
    Waynenorris New Member
    I have a arrow gp2 titanium and link pipe I would swap for ur Taylormade
