Wanted. Translogic quickshifter manual
Discussion in 'Wanted' started by iandanmark, Mar 4, 2016.
  1. iandanmark
    iandanmark New Member
    Does anyone have a soft copy of the Translogic quick shifter manual they could share with me?
    I've just bought a 2012 blade with one on and I want to read up on it. In particular I need to switch it to a new sensor in race shift pattern.
    I've had a look on their website but to download you need the product serial number and I can't check mine because the bike is on its way to Spain :)
    CheersCheers
    Ian
  2. tuktuk
    tuktuk Elite Member
    Ive got one for the newest (is4) mate.
    Pm me your email and il send it over.
  3. brg1000
    brg1000 Active Member
    The translogic needs either a push or pull shifter. It has no idea what road or race shift is. The shifter is pretty much identical to the dynojet one (dynojet make them for translogic). So I dont see what you need the manual for in that regard. Its very easy to determine are you pushing or pulling. Simply simulate a shift 1 - 2 - 3 and it the rod pushes its a push and if it pulls, its a pull.
  4. iandanmark
    I understand all that mate. I'm just an anorak so I like to have all the instructions. :)
