Hm quickshifter intermittent shifting
Discussion in 'Mods, Upgrades, Accessories and Products' started by Chris.93, Mar 16, 2016.
  1. Chris.93
    Chris.93 Member
    As per title, hm plus ss. Sometimes will shift, sometimes won't. Never happens mid ride, some times I turn bike on and it'll work, when working it's perfect! Shifts are super smooth, sensitivity is spot on..
    But others time I start the bike and won't cut in at all.
    I used the main earth on the side of the frame (04 blade, r/h side) that the main loom earth's on to .
    Shift rod is straight, doesn't catch on anything and moves freely.
    Any ideas where to start on this?
  2. racman
    racman Active Member
    yep..bin the fekking thing. just wrote my box off.
  3. sps170373
    I would have said its probably the earth but if you've checked and is ok it must be something else! I'd do a double check just in case
    How long has it been fitted?
    Good luck in getting it sorted
  4. martinowen
    I'm pretty sure there was an issue with the ss on the 04/05, I think the only one that works on this model was the plus
    Could be wrong though just worth checking
  5. Chris.93
    Chris.93 Member
    Well it's
    Well it's earthed same place as the bikes main loom earth's too, was a clean contact area when I put it on.
    I'll go and RE check that though.
    Been on the bike just over a week, been like this for about 3/4 days now
  6. Chris.93
    Chris.93 Member
    Ohh ok then, thanks! I'll drop hm an email
  7. Pgm
    Pgm Member
    What makes you say it wrote your gearbox off ? As in what proof do you have ?
