Received today.
Discussion in 'Mods, Upgrades, Accessories and Products' started by 1premix, Mar 17, 2016.
  1. 1premix
    1premix Active Member
    Got this bad boy delivered from Italy today. RCS 17 with Brembo master cylinder kit. Ordered from Carpi Moto Saturday and delivered today, great service and price. Going on an SP with HEL hoses. Beautiful piece of kit, might just put in a glass case and stare at it.
  2. Dutch Phil
    Dutch Phil New Member
    What's the cost delivered to the door please? And why 17 RCS, isn't it normally 19rcs people choose?
  3. 1premix
    Worked out at €288 to the door or about £220 in English money. Advised by Brembo to go for the 17 due to the smaller pistons in the calipers., will give better feel.
  4. Mr OCD
    Mr OCD Well-Known Member
    Let us know what the RCS17 is like ... I was going to get the RCS19 myself shortly.
  5. Jarryd
    Jarryd Guest
    I also agree, I don't see the point having a 19mm M/C piston unless your calipers have 36mm+ pistons
  6. 1premix
    Will do its being fitted 4th April, with HEL brake lines.
  7. sps170373
    RCS 17 is only for the SP not the standard blade due to the piston differences in the SP brembo's
  8. arthurbikemad
    SP has M4s with 32 and 30mm pistons, the same size in fact as the OEM callipers, OEM master is 17.5mm! When people change to 19mm they get a firmer lever given that the piston is bigger. A piston smaller than 17.5mm would give more power but more travel and less feel, it's all about ratios..
    The formula you need is:
    MC Piston Area i.e. Area of a circle =(3.1416 x piston diameter squared)/4
    Master / Slave = Ratio
    For example:
    Standard M4 monoblocks 34mm 7263.4 / 283.53 = 25.6:1 ratio. Nice ratio.
    Modulation Characteristics:
    30:1 - soft
    27:1 - sweet spot
    23:1 - firm
    20:1 - wooden
  9. sp1n99
    sp1n99 Active Member
    If the piston sizes are the same does that mean the only difference is the name on the outside?
  10. arthurbikemad
    Well, build quality and fulcrum, I.e pivot point, don't know what OEM is off hand but you can change the RCS from 18 to 20mm, 18 for race and 20 for road..
