Problem making hugger fit abs model
Discussion in 'Mods, Upgrades, Accessories and Products' started by Stevie_d, Apr 1, 2016.
  1. Stevie_d
    Stevie_d Senior Member
    has anybody been able to make a hrc Carbon hugger fit their abs model ?
    The design doesn't seem to be the same as a standard hugger. Out of 4 mounting points 3 are all fine, the problem lies with the last one to the lowest right hand side point on swing arm. There is a bracket which clamps around the brake hose, same bracket has a piece coming of which holds the abs cable. I can't move the hugger outwards enough to line the hole in the hugger with tapped hole in swing arm as the hugger hits the rubber around the abs cable. Also cannot move the bracket as it has a locator pin underneath which drops into a hole in the swing arm.
    Don't know the best thing to do, maybe lop a quarter of an inch off the offending area on bottom off hugger, or try bending the abs cable bracket etc. Don't want a bodge really. Quite hard to explain so here is a pic.
  2. Stevie_d
  3. Stevie_d
    Will be a shame if I can't get to fit as it does look well
  4. sps170373
    File off the pip on the bracket
  5. Stevie_d
    It's the rubber it's hitting on ,far side of pip if I file the pip off there will be nothing holding the abs cable in place, don't wanna bodge with cable ties really
  6. iang27
    iang27 Active Member
    If your hugger has the normal metal bracket with two holes for the hugger and one to mount it then it does fit so don't hack anything.
    I think the hugger bracket goes over the brake hose one, will have a look at mine.
  7. dessp2
    dessp2 Well-Known Member
    I hope you get it sorted stevie as that hugger looks brilliant.
  8. Stevie_d
    There isn't 2 holes it's mounted via 3 holes with rubber grommets inside and spacers . If I can't sort it'll be getting flogged . Supposed to be £295 got for £240 delivered . May end up having to buy summat else
  9. iang27
    Ah, right. I thought that it was the same fitting as all the other genuine Honda hugger a with the two bolts you can see at the side or mine.
  10. Ritchierich
    Ritchierich Elite Member
    Put it under the hugger like mine, see photo above.
    Excuse the flaking paint as I didn't use etching premier when I sprayed it same colour as bike.
  11. Stevie_d
    I'll try doing that when I have another bash at it tomorrow
  12. Ritchierich
    Just watch out for the ABS sensor wire routing as it goes under the hugger. This is the second ABS blade I've had and fitted this way with no problem Stevie.
  13. Stevie_d
  14. Stevie_d
    Sorted
  15. graemewalker
    graemewalker Elite Member
    Did you cut the lug off stevie or did you put a 2 or 3mm hole in carbon for locator
  16. iang27
    Notice you have the baffle for your Akra, does it make much difference.
    Just tried my bike down the road, it's bloody loud, I would say Racefit loud or more !
  17. Stevie_d
    Took bracket off , wrapped a cloth round it and bent to required angle . Looks ok
  18. Stevie_d
    It's fairly loud with baffle in , leaving it in until I run the bike in , not that it'll make much difference . Dunno how much louder it will be with no baffle
  19. iang27
    VERY LOUD !
    • Friendly Friendly x 1
  20. Stevie_d
    May leave it in then
