Riding with main beam on
Discussion in 'Mods, Upgrades, Accessories and Products' started by Ravsta, Apr 21, 2016.
  1. Ravsta
    Ravsta Active Member
    Hi guys, does anyone ride with their main beam on? I've got a 2015 bike and I hate the fact that only 1 light comes on. Does keeping the beam on have any negative effect on the light lens?
  2. sps170373
    Tbh I wouldn't ride round with main beam on as you could be held accountable if someone has an incident due to being dazzled by you
  3. Lozzy
    Only time I occasionally put main beam on is in heavy filtering when the gaps are tight & lots of lorries about
  4. murraymint
    murraymint New Member
    I don't, I quite often over take another bike and think there flashing me but there riding with full beam on. Anyways you can't see the front of the bike when your riding it!?
    • Friendly Friendly x 1
  5. Ravsta
    Cheers guys. All valid points. I also put the beam on during filtering especially on the motor way but not for regular riding. But I'm all about aesthetics and equilibrium. I could do with another exhaust on the other side too lol
  6. murraymint
    I do agree though I prefer both lights on. The first thing the other half said when she saw the bike was "you've got a light out!"
  7. Wozza
    Wozza Elite Member
    I always do when I am riding on country roads at speed , one headlight is weak....
  8. Shutty
    Shutty Well-Known Member
    A few times when the sun was low and behind me, got a bit nervous about being seen
  9. red5
    red5 Well-Known Member
    It's illegal..........but riding on main beam does seem to neutralise the invisible cloak of a motorcyclist.
  10. Shutty
    What would happen if you adjusted the beam pattern to a similar level to the other
  11. Barstewardsquad
    GS riders round here seem to be permanently on main beam complete with touratechs to ensure they fully dazzle you before they burn out your retinas.
    Personally I only do so on very rare occasions on some single track roads near home, and the odd nsl single carriage way with some iffy junctions.
  12. Slimwilly
    Slimwilly Member
    so is there a known mod to make both lights come on ,on dip,,if possible
  13. SimonRR
    SimonRR God Like
    two dipped beam were taken from new bike for safety reasons, as at night you tend to look like a car far away due to the lights being so close together, I would just increase the power of your single dipped bulb to an LED or Xeon if i where you mate, my LED is so much brighter then my old blade one was, worth a try.
    #13 SimonRR, Apr 21, 2016
  14. Zanshin
    Zanshin Active Member
  15. Jandy
    Jandy Active Member
    So many people mention the light out thing :mad:
  16. Ravsta
    There are some nice angeleye kits including casings on flea bay. But I'm guessing the wiring will need to be changed in order to have both on at the same time. Too much freaking hassle. Might look into a light smoke headlight protector. That way I should be able to run full beam without dazzling peeps
  17. Slimwilly
    Slimwilly Member
    I have just looked at a spare set of front lights I have and I see the problem, there is only a single filament bulb in each light ,so dip is one light,say left one and high beam turns on the right one which I guess is set to point higher than the left one.
    Easiest solution would be to find a twin filament bulb,,i take it there is none that will fit,otherwise it would be too easy.
    Or drill a hole and put a second bulb in the high beam light to make both lights work on dip.
  18. Ravsta
    There's another thread on this where you can buy a separate loom to reduce the voltage going to the beam. It's a bypass which you can switch off and return to stock from the beam switch. Gonna try that I reckon.
  19. Ravsta
  20. Slimwilly
    Slimwilly Member
    yes I have seen this, but sometimes there is a workshop way to get around a problem,,maybe with a weaker single filament bulb in the aswell you will get two illuminated lights on dip. I will try and show you the results,,oh dear..lol
