DANGER chinese fairings
Discussion in 'General 1000RR Discussion' started by clivo69, Apr 30, 2016.
  1. clivo69
    clivo69 Active Member
    Just broke up at 150
  2. Al_Davo
    Al_Davo New Member
    Off ebay? Maybe you got a bad set.
  3. clivo69
    Dont know they were on when i bought the bike
  4. Blade048
    Blade048 Active Member
    I've had a set on my rr6 for the past 3 years and they're still going strong. I wonder if the way the fairings are mounted on this model causes more stress on the mounting points? I saw a clip on YouTube a few months back where the exact same thing happened to a guy running aftermarket copies on this model.
  5. Slimwilly
    Slimwilly Member
    On my 09 the right hand one came loose..well they are only clipped in with small tabs,,cracked as it was flapping around infront of my foot, another bike stopped me as I could not see it,,i repaired it and used self tapping screws where the lower tabs locate, very easy for it to unclip,,dont trust it really.
  6. sinewave
    Were U on a Trackday Clivo? ;)
  7. Blade048
    Or a closed private road.:D
  8. SimonRR
    SimonRR God Like
    Used them on track days and ok but then there will always be a chance of getting a bad batch I suppose
  9. blake7
    blake7 Active Member
    It's common knowledge, that's why I only do 149 mph.
    • Funny Funny x 5
  10. ShinySideUp
    ShinySideUp Elite Member
    Seen a similar thing happen to an oem set where the front lower clips had not been refitted properly!
    It didn't completely snap off like above but did act like a big umbrella and that happened at less than 70mph! :eek:
  11. Repsol Rob
    Repsol Rob Elite Member
    Mate of mine had a light spill at donnington a few years ago
    A lovely (west racing) R6 Yam...no glue will put it back together
    Chinese plastic don't split..... it breaks into a zillion bits !
  12. SimonRR
    SimonRR God Like
    That why I use Chinese for track days as they cheap to replace compared to OEM
  13. Mr OCD
    Mr OCD Well-Known Member
    It's a problem with the blades of this era as mentioned ... They only have locating tabs on the bottom fairing and so easily pop out if not seated properly, even on the original panels. The top of side fairing clips to the air tubes which are not an issue on the OE stuff but can see why it is on pattern stuff ...
  14. Repsol Rob
    you cant deny that for the money (majority) of those kits offer good value especially when they come finished in team colours etc.....
    • Agree Agree x 4
