Any Plumbers onboard?
Discussion in 'Lounge' started by steve750, Apr 30, 2016.
  1. steve750
    steve750 Active Member
    I'm after a little advice as I need a new circulation pump.
    Many thanks
  2. Slimwilly
    Slimwilly Member
    Ok, first take a piccy of yours , that will help us to advise.
  3. steve750
    It's a circulating pumps 63
    Sent from my HTC One_M8 using Tapatalk
  4. steve750
  5. steve750
    Sorry, CP63 and it's shot it!
  6. steve750
    Would a Grundfos UPS2 suit my needs?
  7. sinewave
    Should be fine the Grundfos.
    If tackling your self the most important bit is to ensure the physical dimensions are the same from inlet to oultlet so as to keep it a straight swap with no pipework alterations
  8. steve750
    Thanks mate. Think they are. Are they all pretty much 130mm?
  9. sinewave
    Most Manufacturers tend to play Ball with each other re fitment.
    Just google the pdf files and check.
    I'm not a Plumber btw (Sparx & Air Con) but do get involved in a lot of FM jobs on commercial prop with involves stuff like this
  10. steve750
    Thanks man.
  11. sinewave
    Just had a quick squint in the Boiler Room and all our pumps are 130mm centres.
  12. blake7
    blake7 Active Member
    Once you have shut the pump valves off, unscrew the middle of the pump to see if the water is still running. Don't take it for granted the pump valves will shut off 100%.
    Have a bowl and some old towels ready.
    May the force be with you
  13. steve750
    Thanks alot mate. I'll let you know how I get on
  14. blake7
    Is a standard CH pump, the grundfos will fit.
  15. blake7
    The boiler has it's own room??? Have you got a butler also Sinewave? :D
  16. steve750
    He's got 2
  17. steve750
    Thanks for the advise guys
  18. sinewave
    I was playing it down tbh, it's actually a mini Plant room!
    We're on a Daikin Air Source Heat Pump so there is quite a lot of kit in there tbh.
    We have 3 pumps as it's a 3 storey House so each floor has it's own pumped loop with a Stat on each floor.
    It got a bit outa hand tbh as it does when building ya own gaff! :eek:
  19. Slimwilly
    Slimwilly Member
    If the big nuts each side of the pump seem stuck, use a hammer and big screw driver or sharp chisel to jar them loose, always works
  20. steve750
    Hammer and chisel worked a treat thanks
