Racefit Infill fitted with the new Akra
Discussion in 'Mods, Upgrades, Accessories and Products' started by iang27, Apr 26, 2016.
  1. iang27
    iang27 Active Member
    Well after looking for an infill panel that I hoped would be able to be fitted with the new 15/16 Akra I bought a Racefit version.
    As expected the angle the link pipe exited did hit the infill but only on the back edge.
    After 30 mins with a Dremel it fits perfectly.
    I could have got away with not trimming it as much but as I want to carry on the white of the belly pan with vinyl I though it was better to have a small gap.
    I must say the bracket that Racefit has designed is fantastic. I would never have thought to fasten it behind the shock where there are two bolt holes already.
    Took a couple of photos in the garage. It is peeing down so they are not great but I wasn't taking it outside.
  2. sps170373
    Didn't you take a more panned out photo?
  3. iang27
    No it was pissing down so I could only go back as far as the bikes, skateboards, scooters and garage wall !
    Will take some better ones if the snow, hailstones, rain decides to stop.
  4. Dave dunlop
    Dave dunlop Elite Member
  5. iang27
    It is quite heavy the bracket, well made. Think it weighs more than the exhaust !
  6. Dave dunlop
    Your not kidding!! Slight overkill is an understatement hence why mines got more holes than a some Swiss Edam!!
  7. sp1n99
    sp1n99 Active Member
    It would be churlish to point out that Edam is Dutch so I won't :rolleyes:
  8. iang27
    Couple of images from further away,
  9. sps170373
  10. Curly
    Curly Active Member
    After hearing you had fitted one and was pleased with it, I ordered one also. And after looking at the photos I am really impressed looks really good. Hopefully get mine next week, I will post some photos, now who I can borrow a Dremel from?
  11. iang27
    If you were in the North East you could use mine.
    I could have cut less away to be honest but I wanted to make sure it had enough clearance.
    It is really secure and well made.
  12. Hedges
    Hedges Active Member
    Cracking job mate! Been considering this exhaust but wasn't sure which infill panels would fit...... Decision made I reckon :)
    Slightly off topic but how loud would you rate the Akra?
  13. iang27
    Very Loud !
    I would say on par with the Racefit or not far off.
  14. 1000rrboyjay
    1000rrboyjay Active Member
    Mate that looks really professional. I've got to say I'd love one for my 09. I've got an Austin one, and to be honest it's absolute shit. Doesn't even line up properly. Which is why SprayBay had trouble painting it. I'm looking at a better fit. I fancy the LeoVince but not sure if it'll go on my Akrapović.
  15. Curly
    Curly Active Member
    Thank you, but I battled on with a coping saw/ file and emery paper! It took me a lot longer than 20 mins!!!
  16. iang27
    You have cut that a better shape than I did.
    I had mine like that but took 'a bit more' off to make sure it cleared !
    Looks great.
  17. 1000rrboyjay
    The bracket on my Austin one broke tonight. Not happy. Made a new bracket to strengthen it. I'd get a Leo Vince carbon one for sure if I didn't have to get it painted. I hate it when shit like this happens.
  18. Curly
    Curly Active Member
    I may have to take more off, it has about 10mm clearance.
    Let's see what happens, I guess carbon fibre should be OK with the heat?
    I am really pleased with it, it just finishes it.
    Then I fitted a hugger which I am not so sure of.
  19. roskal
    roskal New Member
    How much was the infill? Cleans it up nicely
  20. iang27
    They are around £100 delivered, expensive but they fit !
