Rear wheel nut - what size socket?
Discussion in 'Maintenance' started by Rob, Apr 20, 2011.
  1. Rob
    Rob Administrator
    I realised that the rear wheel nut is pretty huge and tried every socket in the garage. Can anyone tell me the socket size I need for the rear?
    Cheers :dance3:
  2. garyauk
    garyauk Active Member
    it was a 36mm on my rr7 blade
  3. JM1
    JM1 Active Member
    22mm I think.
  4. JM1
    JM1 Active Member
    Sorry, it's 32mm
  5. stylo
    stylo Active Member
    RR7 is 33. I know this because every large set goes from 32 - 34. 33 had to bought independently.. Bleedin engineers
  6. flatstickHRC
    flatstickHRC Active Member
    Front is 22 rear is 32
  7. stylo
    stylo Active Member
    How the hell did I end up with a 33? 32 dont fit on mine. RR7
    Will have to verify tonight.
    #7 stylo, Jun 3, 2011
  8. stylo
    stylo Active Member
    Checked and my 32 socket is stuffed so got a 33. Amazingly 33s worked. but 32 it is
  9. flatstickHRC
    A 33 would work just as well anyway TBH. It's a bit of a bastard size. Would never use a 33 on anything really.
  10. Carl
    Carl Well-Known Member
    Rear wheel nut socket
    On a RR5 its 32mm, My previous bike wax a 929 and that was also 32mm
    Hope it helps
