oil ,oil filter,service kits where to buy
Discussion in 'Maintenance' started by manfish78, May 14, 2016.
  1. manfish78
    manfish78 Active Member
    As per title where is the best place to get the bits for a oil service from my nearest dealer is honda farnham is this the best place ? Or can I get cheaper online or from a parts dealer
    Also what oil/brand is recommended for a 08 cbr 1000rr?
    Many thanks
  2. sps170373
    I use castrol power 1 racing 10w30 fully synthetic, oil filter is from honda as is pretty good, don't forget aluminium washer for sump plug bolt
  3. MPJ
    MPJ Active Member
    I went with the same as sps above. You can buy oil/filter together on ebay, I bought seperate last time as I needed the fluted tool to get the old filter off.
  4. bonjo
    Honda OEM kit includes the wrench adapter cup (??) you use to remove and torque the filter. If you don't need that, then you can buy the filter only which is cheaper.
    Hiflow have very good reputation (that I know of) but otherwise OEM is all the way for me. And don't forget the washe sps mentioned
    the oil he mentioned is the original Honda specified brand and type.
    just make sure you don't overfill the engine:)
  5. Spartan Andy
    Spartan Andy Active Member
    I did an in-between main dealer oil change service myself using a Honda genuine oil filter /sump washer & 10w/40 Castrol power 1 racing from Halfords.
    My main dealer also used 10w/40 castrol power 1 racing for my first service oil change last year.
  6. manfish78
    Great thanks couple of different responses regards oil
    Is 10w/40 or 10w/30 the best /correct oil for 08 model ?
  7. sps170373
    From the service manual, 10w30 but you can use 10w40 more important is the 10w part the 30/40 is to do with ambient temperature range
  8. Wolftalker
    Wolftalker New Member
    For my filter I use one that fits the Honda civic of the same year. Much better filter at about the same cost.
    using tapatalk
  9. Jasezxr
    Jasezxr Member
    sounds good i use johnsons baby oil aswell;)
  10. Dave
    Dave Member
    Is the Honda Civic filter rated with the same flow rate as the Fireblade filter then.:rolleyes:
  11. Wolftalker
    Wow I thought this group did it's research. Think you need to all do some on oil filters media and flow rates. While your all being so anal, yet not looking up facts. Kinda like computer motherboards. There are only 5 manufacturers of them regardless of the name on them. The
    So roll your eyes are make other sarcastic remarks, I just let's me know how knowledgeable and ignorant you are.
    using tapatalk
  12. rebel
    rebel Active Member
    I think you'll find the 30/40 bit is the important bit it's the viscosity 40 is to thick
  13. benp1
    benp1 Active Member
    I need to do an oil service on my 08 blade
    What do you need the oil filter tool for? I normally tighten filters by hand, and remove with a chain tool or similar
    Does anyone bother doing the air filter? Is it worth it?
  14. Jasezxr
    Jasezxr Member
    I thought u were joking is all, I was joining in.
  15. rebel
    rebel Active Member
    went to a car boot last week picked up a air filter for an old Cortina cut it down with a pair of scissors
    fits the blade a treat
  16. Dave
    Dave Member
    Think wolftalker is taking this forum a bit to seriously:(
  17. Wolftalker
    Yes, I suppose I am. My apologies if I offended anyone. everything going I do is serious. Making that perfect Li en at the perfect time, executive get the perfect pass. Being technical is very fun to me. I didn't understand the joke. I'll go back to hiding under the bridge and keep my mouth shut.
    using tapatalk
  18. stevet
    stevet Active Member
    Wrote to opie oils about best oil to use in me 14 blade....they recommended these... 20160624_152932-1.jpg
  19. Julian
    Julian Active Member
    What is this washer your talking about ? I have never needed one on my r6, about to do my first change on the blade, do I need a washer ? If so what size and is it any old washer or do I have to pay through the nose from a dealer ? Tell me more !!!
  20. Dave
    Dave Member
    Julian, the washer the guys are speaking of is the sealing washer that you will find on the sump plug. As a matter of course it should be replaced but you can sometimes re-use the existing one but they are only pence to buy.;)
