Folk Marks
Discussion in 'Maintenance' started by Spartan Andy, Jun 10, 2016.
  1. Spartan Andy
    Spartan Andy Active Member
    My 2015 1000rr front folk is looking not too well. It's not leaking oil, but not the normal rings marks usually see on other bikes. Looked around on the web for help without much success. Is this normal?
    Thanks for any suggestions
    #1 Spartan Andy, Jun 10, 2016
  2. TheRamJam
    TheRamJam Well-Known Member
    Looks normal to me. Give them a good clean and they should be ok. When was the last time the forks were serviced?
  3. Spartan Andy
    Hi & thanks for advice. Folks never been serviced as bike is 12 months old, The other side folk has just light rings marks. I did try the coffee cup trick with inserting the side of cup to clean any muck out maybe trapped between the seal.
    But if just normal then happy to leave.
  4. dansp1
    dansp1 Active Member
    I fixed a weeping fork seal with a bit of 35mm film the other day
    that's all folks
  5. sulaco
    sulaco Active Member
    This looks handy http://sealmate.net/, but I guess any non sharp flexible piece of plastic will achieve the same result.
  6. blake7
    blake7 Active Member
    For Folk sake someone let him know, poor lad. :D
  7. Spartan Andy
    All done and fixed. Used ham packaging which I cut out a -C- shape grove. Dropped the dust seal this time and did a spin with the ham packaging, job done.
    Also cleaned the dust seal for good measure. Just came back from a ride and all good.
    Thanks to all for the advice.
    #7 Spartan Andy, Jun 10, 2016
  8. Dave
    Dave Member
    Gendarme from Allo Allo springs to mend!:D:D
  9. Spartan Andy
    Bit a of a 'Heath Robinson' also springs to mind.
    Just got back from a ride this morning and apart from the usual rings marks from both folks and not the veritigal marks.All good.
    As RamJam said above, they needed a good clean.
  10. And7rp2
    And7rp2 Elite Member
    folking ell, is someone gonna mention it ??
  11. sinewave
    For Forks Sake, grow up U lot! :rolleyes:
  12. blake7
    I've done folk all wrong pal :D
  13. And7rp2
    Fork all to do with me either :D
    #13 And7rp2, Jun 12, 2016
  14. Barstewardsquad
    Fork Handles?
  15. sinewave
  16. dansp1
    different strokes for different folks
  17. Spartan Andy
    That's All Folks :)
    I Meant Forks - Yes I Know :confused:
    #17 Spartan Andy, Jun 16, 2016
  18. blake7
