CBR1000RR DYNOJET POWER COMMANDER SFM QEM AND QUICKSHIFTER
Discussion in 'Parts, Accessories & Clothing' started by brg1000, Jul 10, 2016.
  1. brg1000
    brg1000 Active Member
    I HAVE A 16-034 POWER COMMANDER 5 WHICH IS SUITABLE FOR ALL CBR1000RR 2008 - 2016. THE OTHER PCV WILL ONLY FIT THE 08 - 11 AS THEY REVISED THE FUEL INJECTOR SUB LOOM ON THE 2012 BIKE. THE 034 PLUGS INTO EACH INJECTOR. COMES WITH O2 SENSOR ELIMINATOR
    £185 ONO
    SFM - SECONDARY FUEL MODULE.
    ALLOWS THE POWER COMMANDER 5 TO FUEL THE UPPER (SECONDARY) INJECTORS AND USE A QUICKSHIFTER. ANY QUICKSHIFTER CAN BE USED WITH THIS.
    £125 ONO
    QEM - QUICKSHIFTER EXPANSION MODULE
    PLUGS INTO THE UPPER INJECTORS AND CUTS THE FUEL WHEN USED WITH THE PCV AND QUICKSHIFTER. CAN ONLY BE USED WITH A NORMALLY OPEN CIRCUIT QUICKSHIFTER. TO TEST THE QUICKSHIFTER SIMPLY CHECK IF CURRENT FLOWS WHEN THE SHIFTER IS IN ITS REST POSITION. CURRENT SHOULD NOT FLOW WITH A NORMALLY OPEN CIRCUIT.
    £60 ONO
    QUICKSHIFTER. DYNOJET NEW SMALL RED NORMALLY OPEN SHIFTER. COMES WITH LINK ROD
    £125 ONO
  2. paullec
    paullec Active Member
    ill take the pcv mate !!!!
    got a 2013 version so should fit
  3. brg1000
    It's yours Paul if you meet my asking price same for Aaron and the other lad.
  4. paullec
    ill do 185 then
  5. brg1000
    no bother Paul. It's [email protected] or Santander. 08-01-28 acct 53950780 is my bank. Give me exhaust serials etc and I will post weds as our post offices are closed here tomorrow. 07921849076 is my mobile.
  6. hoggyjay
    hoggyjay Active Member
    Is the quickshifter and expansion modual still up for grabs?
  7. brg1000
    Yes. Only the power commander sold.
