Brand new in the packet. Superb bit of kit. More information here: http://shop.12oclocklabs.com/index.php?route=product/product&product_id=59 The smallest electronic speedometer/odometer calibration device in the world. Saves max speed, which can be recalled to your stock speedometer gauge Widest calibration range on the market (ratio based and multiplier/divider capability) Built in testing mode to ensure proper installation Easier to setup than any other device on the market Simple plug-in installation for many vehicles using factory OEM connectors Ability to convert MPH to KPH, or KPH to MPH Ratio based correction in 0.1% steps, up to 99.9% + or - Fractional frequency multiplier & divider with 0.1 steps, up to 99.9 + or - Weather proof design to protect against the elements 18" wiring harness (1.5ft) £50 delivered.
You having a clear out...lol Would I benefit with this on my 2015 blade? Just running an after market can... Sent from my SM-G925F using Tapatalk
Yeah... just a few bits of pieces had lying around It is for people who have / or will change the gearing (sprockets) on the CBR... when you do that it throws out the speedo reading... as it is already approx.. 10% out as standard. If you change the gearing to -1 / +1 or +2 the speedo can then be approx. 20% out.... which means your putting miles on the bike you haven't done as well as the speedo reading being very inaccurate. Speedo Healers are £100 new, so this is a bargain and better IMHO.
