My Blade is injured - but 'WILL BE BACK"
Discussion in 'Pictures & Videos' started by Gareth Morgan, Jul 24, 2016.
  1. Gareth Morgan
    Gareth Morgan New Member
  2. blake7
    blake7 Active Member
    Oh dear, Cat B write off due to frame damage?
  3. Greco
    Greco Active Member
    Now that is a big skid!...and costly..
  4. Gareth Morgan
    No, frame is straight (been jigged), front forks square, so turning it into a street fighter now. I normally ride a Multistrada, so like the higher bar position and removing the fairing saves about 40lbs in weight. Will spend some money on it and have it back on the road (hopefully) before Autumn with custom paint, raised bars and relocated electrics. May post some photos.
  5. Gareth Morgan
    I see you're in Nottingham fella - so am I. Know any good motorcycle electricians, I need to re-route the electrics for the ECU and fuses?!
  6. sps170373
    Fairings removed will loose weight but not 40lbs/18kgs
  7. blake7
    I don't know anywhere that does looms specifically pal. There are places that you can send it off and they will make it to however you want it.
    You could try calling Kev at KS Performance in Hucknall, he builds race bikes so he should know someone 077 241 48423
  8. Gareth Morgan
    Thanks chap!!
  9. Gareth Morgan
    An exaggeration on my part to make a point - you're right, but check out attached - its compelling! 2016-07-24_22-31-59.jpg
