n00b friendly rearsets
Discussion in 'Mods, Upgrades, Accessories and Products' started by beckylou, Sep 9, 2016.
  1. beckylou
    beckylou New Member
    Hi,
    Are there any rear sets for a '14 blade that don't require changes to the rear brake master cylinder nor splicing into the electronics?
    The rearsets I've seen reviewed either need the brake light switch bolting onto the top of the master cylinder; or another switch splicing into the electronics. I'm hoping for something that's just plug and play without any faff.
    Do they exist?
  2. poppy72
    poppy72 Active Member
    I've got gilles you need to cut brake light off attach switch supplied by gilles really easy job I must say they are brilliant
    Sent from my GT-I9505 using Tapatalk
  3. beckylou
    beckylou New Member
    That doesn't sound so bad; I guess I could always add some connectors to the brake switch. I don't want to leave myself in a situation I can't put the stock sets back on the bike in case I don't like them - I spend a lot of time on my bike 12k miles per year.
  4. Carl Abbott
    Carl Abbott Active Member
    Hi,
    I know that the Gilles A31GT rearsets utilise the OEM brake master cylinder/switch. And I believe the same goes for some Rizoma rearsets
    Admittedly I have only been looking from an 08 Blade point of view.
  5. ColinBR
    Yea Rizoma rearsets use the OEM gubbings.
    I've just taken a set off of my 2010 bike.
  6. ColinBR
  7. poppy72
    Yeah gilles comes with connectors easy instructions
