race fairings
Discussion in 'Mods, Upgrades, Accessories and Products' started by skyracer, Sep 26, 2016.
  1. skyracer
    skyracer New Member
    just removed all my stock fairings. to put on race fairings.could anyone please help me out with what i do with all the wireing.dont really no what i need to keep and what i can take off help please
  2. racman
    racman Active Member
    hi skyracer, cant really help with your question at mo, but interested as to where you purchased your race fairings as i am about to do the same to my 06 but cant find anywhere to buy from. what model year are you converting?
  3. Muffking
    Manly just cable tie it all down so i t doesn't move, but depends on whether you will be switching back to road fairings or keeping it as a track bike?
  4. skyracer
    skyracer New Member
    Thanks for the reply . Silly question but what do I do with the air sensors in the fairing please
  5. blake7
    blake7 Active Member
    If you are using the existing the air tubes then leave them in, if you are using race ones with the race fairing, just unplug them.
    Cable tie and tape up all cables that will no longer be needed. You will need to make a bracket to relocate the tip sensor as it is attached to the headlight. The horn can stay and left wired as it does not get in the way.
  6. skyracer
    skyracer New Member
    Does it make any difference if you unplug them
  7. blake7
    No, the system is designed to control and cut emissions. Most just remove the vacuum and valve and then tape over the hole with some gaffer tape. You need to then also remove the flap inside the tubes.
    Have you done the servo mod and pair system mod? or are you going to?
    Have you got a power commander or similar?
  8. skyracer
    skyracer New Member
    I think I have bitten off more than I can do .. all I have done is remove the stock fairings so far.
  9. skyracer
    skyracer New Member
    I was going to leave the wires and so on so that I can put back to road bike when I sell it .
  10. blake7
    You have not, no need to worry mate. You have an after market exhaust so I'm guessing the servo mod has been done.
    Just unplug the solenoids from the air tube and then fit the race ones. Or leave the original tubes in place and fit race fairing on with everything still connected on the tubes.
    Just make sure you fit the tip sensor on the race fairings or the bike wont run.
  11. skyracer
    skyracer New Member
    thanks mate I will have a go over the weekend I think I will put the original air tubes back on . Got new levers to go on and adjustable rear sets . And engine covers . Then I will buy a power commander I think
