2007 cbr 1000 clutch problem..
Discussion in 'General 1000RR Discussion' started by Graeme Macleod, Sep 30, 2016.
  1. Graeme Macleod
    Graeme Macleod New Member
    Clutch on the bike is disengaging suddenly when I am trying to launch the bike when the clutch lever ain't even released fully and nearly wheelied me off the bike.cannot ride the clutch for a quick take off I don't know what is causing this can someone help me on this.or has anyone experienced this,could it possibly need a fresh fluid changer or newan clutch needed.
  2. Muffking
    Is the biting point on the limit of where the lever is pulled right in?
    Does adjusting the lever position make any difference?
    Failing the above, bleed the clutch slave.
  3. Graeme Macleod
    Just bled the clutch new fluid still the same it actually feel like the lever pushes back at my fingers weird slave cylinder must be broke.surely someone else has had this issue.
  4. Muffking
    You could unbolt the slave and test it with the hydraulics still connected as there's no fluid behind the slave, it just pushes on a rod. You could use this to test that it's actually pushing the rod properly.
  5. bonjo
    can hydraulic clutch suffer from, ageing, air or moisture (like in brake fluid)?
  6. Muffking
    possibly, but more likely a failure in the hydraulic pressure. Say it leaked for example, then the clutch wouldn't disengage properly or at all.
