Exhaust recommendations for track days
Discussion in 'Trackdays' started by Glenn2605, Oct 23, 2016.
  1. Glenn2605
    Glenn2605 Active Member
    Hi All,
    As in the title I'm waiting to find out what exhausts people are running for track days, I tried to get on at Castle Combe this year with the standard can and it failed the noise test - I have a 2010 blade.
    Cheers,
    Glenn
  2. sps170373
    If you failed with the standard can there I don't think any aftermarket exhaust is gonna pass to be honest at castle Combe
  3. ColinBR
    MHP exhausts are about as good as you can get for getting the noise levels down
  4. Glenn2605
    This is teh feedback I've had from others as well, I have a winter to work on it so fingers crossed..
  5. oldbutgold
    oldbutgold New Member
    Colin is right . Mhp got my arrow system down from 109db to 99db. Very nice work too
  6. Glenn2605
    Which arrow system do you have out of interest?
  7. oldbutgold
    it's an earlier race system originally supplied by Padgetts.
    It uses the trophy 48mm slip on silencer.
  8. Glenn2605
    Any thoughts on a full Leo Vince SBK system?
  9. racman
    racman Active Member
    on the same subject, has anyone done a trackday with the scorpion serket taper end can. i had mine noise tested at cadwell today. it blew at 110db. but the bike had only been run at idle for 10 mins before the test. i presume if i had ragged it a bit before the test it may have blown a little lower.
    i have spoke to scorpion who have a db killer available but advise would only normally reduce this reading by 3-4 db
  10. Scott
    Scott Active Member
    Will never make it low enough
