X-lite 802-r lining removal
Discussion in 'Lounge' started by Barstewardsquad, Jan 17, 2017.
  1. Barstewardsquad
    Hello strangers
    Does anyone have any pics that would should how the lining is fitted on this lid? I can remove most bits but I'm not sure about the main side bits and I want to remove them to fit some cables.
    I watched @lambchops video on fitting the sena headset and it looks like they can be removed but I couldn't get a good view on the fittings used to secure them.
  2. sulaco
    sulaco Active Member
    I don't have an 802r, but I do have a 701, and have had others X-lite in the past. The cheek pads are fitted but push stud type thingys, I just gave mine a gentle tug and they popped off, and the plastic strip around the bottom slips inside the shell. A pic of the pads:
    Hope this helps a bit.
  3. Barstewardsquad
    Thanks. I thought the cheek pads were like that, but I also want to remove the pads behind them as you look from the front, the ones with the side skirts on them.
