1. steve0202
    steve0202 New Member
    Evening all. Iv got a rr6 and when I brake I have a pulse in the lever and judder on front end, I my thoughts straight away is that it's the discs but before I spend money on new set is there anything else that it could be? All the help would be great.
  2. sp1n99
    sp1n99 Active Member
    First try cleaning the bobbins, they tend to stiffen up if they're not cleaned properly.
  3. steve0202
    Thanks but what do you mean by bobbins?
  4. Muffking
    He's referring to the metal rings in each disc as the bike has floating discs where they move sideways slightly to stay central to the callipers as the pads wear. The metal rings should spin freely, but can be cleaned up if they're seized.
  5. ColinBR
    Check wheel bearings and headstock bearings
  6. steve0202
    Okay that's great did not know that will have a look tomorrow and find out.
  7. Muffking
    Do check Colin's suggestions too though, it may be quicker to lift the front and see if the wheel or steering have any play which could also cause your issue.
  8. Kevin1
    Kevin1 Elite Member
    warped disc(s)?
  9. sulaco
    sulaco Active Member
    Here's a little vid I watched when I needed to do mine for the first time.
  10. steve0202
    Thanks is this fix your problem?
  11. Slimwilly
    Slimwilly Member
    I have seen this due to contamination,,wd40 , fork oil or similar
  12. sulaco
    Sorry not been on for a while , But yes It fixed my problem.
