Akrapovic installation
Discussion in 'Mods, Upgrades, Accessories and Products' started by gawain53, Feb 10, 2017.
  1. gawain53
    gawain53 New Member
    Hi guys,
    I'm going to install a Akrapovic slip on carbon muffler and I have two questions:
    I guess the current OEM muffler gasket will be broken when I will remove the current muffler, should I buy a new one or will be included in the Akra muffler?
    I saw in some of your bikes that is possible to install a filler panel that protects the muffler pipes.
    Where can I buy one panel that fits the Akrapovic Slip on?
    Many thanks!
    Enviado desde mi iPad utilizando Tapatalk
  2. stupot
    stupot Active Member
    I've never seen an Akky one but Yoshimura do one. Calsport sell them. May need fettleing though
  3. charger
    charger Active Member
    gasket not needed
  4. rikvanbeek
    rikvanbeek Member
    I pulled the original gasket out of the OEM exhaust. It's a bit time consuming, and it will not stay new... but it fits like a charm.
    A new one doesn't cost the world though.
  5. Dave dunlop
    Dave dunlop Elite Member
    No gasket required, and your need to shop around for a panel as not many will fit with the carbon slip-on low slung unless your willing to modify it yourself...the Megaphone in the picture will only fit 2014 models onwards and SP, and you still have to modify the Racefit panel to fit...
  6. Dave dunlop
  7. Dave dunlop
  8. Dave dunlop
  9. gawain53
    gawain53 New Member
    Many thanks!
    Beautiful machine Dave!
  10. Jez
    You should not post pics like that, It is going to cost people a lot of money. Now how much have I got in my Paypal account I'm sure I need some new calipers
  11. 1000rrboyjay
    1000rrboyjay Active Member
    Sexy rear wheel and calliper Dave
  12. gawain53
    gawain53 New Member
    I already installed the muffler.
    It fitted well but there is a little leak in the headers conexion.
    Did i place fine the clamp?
    Thanks![​IMG]
    • Optimistic Optimistic x 1
  13. Dave dunlop
    You can place the clamp around further if you want, just as long as it clears everything and you can still get to it once everything is back in place, it will also move the thread around so it's not picking up water and road muck.. you need to clean both surfaces and make sure you haven't picked up some deposits of road muck, make sure the clamp is we'll nipped up and you should be ok.
    #13 Dave dunlop, Feb 22, 2017
  14. Dave dunlop
  15. gawain53
    gawain53 New Member
    Many thanks Dave.
    As always really good help from you!
    Do you recommend me to add a bit of silicone gasket?
  16. Dave dunlop
    Your welcome, as long as both surfaces are spotless and it's nice a tight you shouldn't need any sealant, but if you worried about any interface imperfections then it won't hurt to give it a very light smear, just don't use exhaust cement as tends to go off rock hard.
  17. Sgt
    Sgt Active Member
    Hello guys, did anyone find a heat shield, cover to fit, or was the yoshi cover fit with a bit of messing around...
  18. 1000rrboyjay
    I've used Austin Racing, however I would have chosen the Leo Vince if I'd seen them before I bought the Austin. It's alright but I had to get a mate to make the mounting bracket as with a full system there is no S bend.
    I also had to file the Austin one to fit quite a bit to get it to sort of fit..
  19. Sgt
    Sgt Active Member
    Nice, but looks like it's arching down...... I wonder where the carbon fibre one in the first post was bought from.....
    Was it this item from eBay? 162202683128
    Apparently doesn't fit 2014+ :(
    #19 Sgt, Feb 22, 2017
  20. 1000rrboyjay
    Yeah that's the trouble. I will eventually get one. But it's the hassle of getting it resprayed to match.
    £95 on eBay mate
