Vinyl Wrap Whole Bike
Discussion in 'Mods, Upgrades, Accessories and Products' started by Singh1000RR, Nov 27, 2016.
  1. Singh1000RR
    Singh1000RR Active Member
    Hi, anyone had experience of vinyl wrapping whole bike?
    Had totally polar views when doing research.
    One company said don't do it as heat from vents will warp and peel it.
    Another has said that if you use a better quality wrap it is ok.
    I've been quoted £1200 for a full respray and been quoted £300 for a wrap.
    Had paint work done by dream machine in the past and it started to go after 4 years even after special care.
    So any experience/views would be appreciated.
  2. martinowen
    Seen a few pealing or bubbling from the heat, no idea on the qualities used though
  3. sps170373
    Am sure I read somewhere that wrap/vinyl only last 4-5 years at most! My concern would be the removal process
  4. tuktuk
    tuktuk Elite Member
    Mates just had his track bike wrapped.
  5. stupot
    stupot Active Member
    Google or Facebook "Chalkies Decals"
    He is does wrapping and vinyl race liveries.
  6. Outdoor_funguy
    Outdoor_funguy New Member
    I got my Vinyl Wrap from Gatorwraps . They have a lot of wraps, 3M Vinyl Wraps or Avery Denison Vinyl Wraps. You might also want to visit Gatorprints
  7. sinewave
    When I looked in to it for my Track Bike I still found paint cheaper.
  8. stupot
    Chalkies decals do a great job
    Sent from my Pixel using Tapatalk
  9. Jez
    Hi, I wrapped the sides of the tank with 3M carbon film they looked great but with the heat they started to peal a bit. during the winter I have redone them using 3M primer on the edges it does stick a lot better I am hoping for no lift this year, The thing is you don't need a lot of heat to put it on so heat from the engine will also bring it off more so where streched
  10. Fatboyslimish
    Fatboyslimish Active Member
    Mines been on for 3 plus years
    Sent from my SM-G920F using Tapatalk
  11. Jez
    Fatboy yours does look like an adult has put it on rather than someone buying of ebay like myself
  12. Fatboyslimish
    Done by a local van wrapping company. Only charged £150 for design, print and install
  13. Jez
    I think its a bit like plastering anyone can do it but the results are totally different
  14. Sgt
    Sgt Active Member
    You could just get an aftermarket full fairings for £250.00 - £500.00. Just google and a shed load will pop up...just the ball ache of changing it!
