Hello
Discussion in 'New Members' started by saabowl, Feb 18, 2017.
  1. saabowl
    saabowl New Member
    Hi,
    Bought a 2005 1000rr at the end of last year and braved the weather to give it its first ride of this year today.
    I've not had a sports bike since the 90's and have spent the last few (20!) years on harleys and the like.
    The bike had a scottoiler fitted but it was removed just before it was sold to me.
    It's not as fast as I expected. I am aware scottoilers connect into a vacuum circuit. Could this cause loss of performance if it wasn't disconnected properly?
    Or could it be I'm not totally used to revving a bike yet?
    Handling is amazing and the engine is smooth, but want to be sure it's going as it should.
    Thanks
    Mark
  2. sps170373
    Welcome to the forum
  3. sulaco
    sulaco Active Member
    Hi and welcome to the forum.
    As far a your problem goes, have a look under the seat and in the tail unit for the scottoiler tube (assuming it's not been removed properly) most people route them through the battery compartment into the excuse of storage in the tail unit. If you find it just block it off or trace it back and remove it. I'm not sure it would impact the performance, the only issue would be the possibility of sucking a little extra unfiltered air. As far as it not being a fast as you expected, I think it's probably because it's so smooth and handles great it doesn't feel manic, but if you give it some, it will certainly go. I have an 05 as well, the rear sprocket is +2 from standard, livens it up a bit but don't knock the speedo too far out of whack.
  4. saabowl
    saabowl New Member
  5. saabowl
    saabowl New Member
    Thanks. Doesn't seem to be any tubing under there.
    Like you say the handling is amazing
  6. rewy..rr
    rewy..rr Active Member
    Welcome
  7. BlackDevil
    Hi and welcome Mark !
  8. Jandy
    Jandy Active Member
    Welcome along !!!!!!
  9. SimonRR
    SimonRR God Like
    Welcome, I used to own the RR5 too, dropping the front sprocket to 15 and increasing the rear to at least 42 ( I used 44 on track) will increase your fun no end, however it will drop your top speed
  10. bradt
    bradt Elite Member
    Hi and welcome.
  11. Nickw
    Nickw Active Member
    Hi Mark, welcome to the forum. Enjoy your bike. They are a great litre sports bike that are relatively easy to ride. Still got to respect them though.
