Any car mechanics on here?
Discussion in 'Lounge' started by TheRamJam, Apr 12, 2017.
  1. TheRamJam
    TheRamJam Well-Known Member
    My car wouldn't start this morning :-(
    Was driving fine yesterday as i drove home from work. Gets up for work this morning and its not starting. The battery is strong and you can here the starter motor whirring away.
    I think it may be some sort of sensor that's gone.
    Its a Vauxhall Corsa 2009 1.2 SXi with 57k on the clock.
    Any ideas would be great thanks
  2. stupot
    stupot Active Member
    My mums 1.2 corsa did this last year
    Turned out it was the fuel pump relay
  3. Muffking
    Should be straight forward to diagnose being a petrol.
    Are there any errors? Do you have a plug in diagnostic tool?
  4. TheRamJam
    Thanks for the replies lads.
    I don't have a diagnostic tool mate no.
  5. CBRGav
    CBRGav Active Member
    Can you hear the fuel pump running when you switch the ignition on? If not check for fuel cut off reset button ( Google for exact location) I'd check that first if it were mine
  6. CBRGav
    From looking it could be a fuse not a switch on the later ones. Worth a look before going into bigger more expensive options
  7. TheRamJam
    Yeah Gav
    I can't hear the pump priming when I turn the key to position 2.
  8. CBRGav
    That'd be where if be looking first switch/ fuses, then relay, then finally pump not done much on the later stuff tbh but that's the way I'd be looking
  9. TheRamJam
    Cool ill look at some fuses and relay's etc
    One guy said it may be the Crank sensor so i'll try and check that too
  10. Dave dunlop
    Dave dunlop Elite Member
    100% crankshaft sensor!! Friends one had the same last year and it's well documented, changed it for her in about 30 mins, you need to get the car as high as possible and climb under and to the back of the engine, towards the bulkhead.
  11. Cbrjay
    Cbrjay Well-Known Member
    Check for feed at fuel pump, try hitting bottom of fuel tank in case pump sticking
  12. TheRamJam
    Bingo Dave.
    It was indeed the crankshaft sensor. Car now starts and runs fine.
  13. Dave dunlop
    Happy days..... :)
