Glasses friendly helmet
Discussion in 'Lounge' started by rebel, Jun 1, 2017.
  1. rebel
    rebel Active Member
    I'm just about to turn 60 and I should be wearing glasses when I ride can someone recommend a glasses friendly helmet I have tried a couple of helmets hjc agv but there still really difficult to use with glasses.
  2. tuktuk
    tuktuk Elite Member
    I bought some cheap glasses to use when riding, really thin frame and the lenses sit quite close to my eyes. My normal glasses were uncomfortable and i was always looking over them after a few mins riding.
    Using rx7v atm but was same with shoei.
  3. Nickw
    Nickw Active Member
    Try Oakley frames with the straight arms. That way you don't have to hook them over your ears.
  4. Gaffa22
    Gaffa22 Well-Known Member
    Shark do glasses friendly helmets, they design the upper part of the cheek pad to accept glasses, I also have a Shuberth C3 Pro which is fine with glasses.
  5. sulaco
    sulaco Active Member
  6. Ian63
    Ian63 Active Member
    Straight arm glasses are your best bet. Bit of a faff but stay put once in
  7. MrIII
    MrIII Active Member
    I use a Shoei Multitec and its fine with my Glasses.
  8. TheRamJam
    TheRamJam Well-Known Member
    Shark
    Have pull out pad designed for folk with glasses in mind
  9. SpeedoX
    SpeedoX Active Member
    I use Shoei XR1100 and it is glasses friendly as they're grooves in the padding for the glasses.
  10. bonjo
    My shoi xr1000 s good with spectacles.
    one important measurement I always make is the total width of the frame (including the hinges) which will affect the way the arms bend or sit on your sides and the pressure behind the ear
