Head Bearings ... when did you last check yours?
Discussion in 'Maintenance' started by Mr OCD, Jun 14, 2017.
  1. Mr OCD
    Mr OCD Well-Known Member
  2. Muffking
    Shouldn't that have been picked up at MOT time?
  3. Mr OCD
    Not really. It can't be seen without dismantling and you can't always feel any play / slack in them from lifting the front wheel.
    I've got a very slight vibration when braking hard... I suspect this is the culprit.
  4. Muffking
    In that case, well found :cool:
  5. Mr OCD
    To be honest after having the forks serviced, replacing the wheel bearings, brake discs, brake calipers and pads along with the MC it couldn't have been anything else!
    :D
    Fingers crossed!
  6. Cbrjay
    Cbrjay Well-Known Member
    I always change mine for tapper rollers and inspect once a year and re grease
  7. Mr OCD
    Exactly what is being done at the moment.
  8. Mr OCD
    Sorted. All vibes gone :))
  9. PeterT
    PeterT Active Member
    Mine after about 10,000 miles
  10. Mr OCD
    WOW!
    10,000 miles? - They are taper bearings as well so not originals?
  11. PeterT
    No they are Koyo and expensive.
    I did hit a rather large pothole and this probably broke the bearing and seal.
  12. Mr OCD
    Damn.
    I've had Koyo taper put in my bike ... so smooth :)
    • Old Old x 1
