Bar end weights - Advice
Discussion in 'Mods, Upgrades, Accessories and Products' started by nigelrb, Apr 22, 2018.
  1. nigelrb
    Anyone use weighted bar ends for smoothing out vibrations - or are they just an 'old wives tale'?
  2. Jez
    I'm with you on this one I made stainless ones for mine, mainly for looks, but it is fitted with the factory steering damper, am I just adding weight
  3. nigelrb
    Thanks Jez. Does the added weight make a difference? I'm trying to find out whether they're effective or not. Cheers!
  4. raphael
    I find the standard bar ends are better/heavier than any of the aftermarket ones at reducing vibration. I have actually gone back to standard from the r & g ones
  5. PauloHRC
    What if you wanted to fit a front brake lever guard? That would mean you have different weights on the end of each bar. Would that cause vibrations??
  6. raphael
    I have looked at the lever guards for mine as have a good master cylinder and levers but as they are a racing item I would imagine they will be lighter than the standard ones so not bothered until I know different
  7. dainesefreak
    dainesefreak Senior Member
    Heavier barend weights are supposed to make a difference, finding the things is another story. I did read a thread on a forum with a guy who made his own, can't remember if it was here??
    I just bought some gloves with a "Rossi Tickler".
  8. nigelrb
    Not applicable to me. I don't get close enough to anything to make contact.:D
