  1. PauloHRC
    It's a slow process this......mainly due to time, but made a bit more progress today. Just the belly pan and nose cone/fairing to do now and after today should be an easy job to finish. Those flapper things inside the air ducts were a pain in the arse and there's so much shite fastened to the inside of the fairings!!! Anyway nearly there now. Can't wait to put some stickers on it! ;)
  2. Selmer50mark
    Its Looking good Paul , even with a red nose ;) stealth blade
  3. nigelrb
    Glad it's coming together. With all the time you've spent on it you've saved about 500 miles:)
  4. Alan-lee
    Alan-lee Active Member
    71BB8748-8E09-4CE2-93AB-C5C0813723B2.jpeg I made the mistake of buying an eazi guard kit and fitting it myself
    3 hours later and a broken back
  5. Muffking
    The problem is that hairdryer. Are you sure you know how to use it :D
  6. Alan-lee
    Funny you say that.. it was quite the struggle drying it through my own hair but I got it done! Haha
  7. Selmer50mark
    Prep my RRV for a MOT , had to whip out the neutral switch from the side of the engine and give it some tlc , the light wouldn't go out when it was in gear . It goes to show if you leave things standing for a long time little problems like this pop up .sorted now , ready to put back on the road (if it passes );)
  8. nigelrb
    Not necessarily so. I left an ex-wife standing for a long time - didn't present any problems to me!:)
    • Downvote Downvote x 1
  9. PauloHRC
    And then she was black! :D
    • Like Like x 6
  10. Selmer50mark
    Looks well smart , New exhaust as well or original with a sticker , do the mirror blanking plates act as indicators Paul ?
  11. PauloHRC
    Cheers Mark......standard exhaust with a heatproof arrow badge I've had lying around for years! You no what I'm like for a sticker!
    There'll be no need for indicators where I'm going Mark!!! ;)
  12. Selmer50mark
    Too true, hope the weather is good for ya , just watching bsb at Oulton now
  13. Alan-lee
    Looks well!!
  14. gaz22
    gaz22 Active Member
    Just finished getting my track bike sorted
    Got the paint codes also for the tt colours
    For the white I just used Frozen white
    Red is Honda Winning Red R258
    Dark blue is Kawasaki metallic ocean blue 726
    Light blue is Suzuki metallic triton blue YSF
    The white on the original is a pearl paint not sure on this code but very similar to frozen white but a fraction of the cost
    • Like Like x 8
  15. TheMickster
    TheMickster Active Member
    Nice, who did you get the race fairings from? does the rear seat unit slide over a standard rear subframe?
    Mike
  16. gaz22
    gaz22 Active Member
    Yes the rear seat unit does fit with the original subframe, you do however need to grind off the bolt casting that hangs underneath that holds the two halves of the subframe together. I made a flat plate bracket to bridge across the rear of the subframe and riveted this on then cut off the bolt on the underside of the Oe subframe, when you take off the rear seat unit this will become quite obvious
    Link below for fairings, speak to Richard first if you want this seat unit as you can’t buy it direct from his website, also don’t get mixed up with pro-fiber that are a foreign website
    http://www.profibre.co.uk/
  17. Lozzy
    Had the smaller plate made ready for the new bike....
    None a that Pansy Potter HRC riders expensive personal plate nonsense going on here :cool: ;)
  18. PauloHRC
    Cheeky FUKA!!! :D
  19. Lozzy
  20. Alan-lee
    502B00BB-F6B7-44BF-B314-6E24209A4B96.jpeg 8A0BDE49-1843-47F6-9D6E-9994BE0431D0.jpeg Well I done my first 5 mile on the expensive twat hrc plate lol
