Help, RR7 cut out at 9000rpm
Discussion in 'General 1000RR Discussion' started by Selmer50mark, May 7, 2018.
  1. Selmer50mark
    When I got to 9000rpm under load the bike seem to cut out like a throttle shut off for a second , then picked up again while I was on full twist off the throttle, caught me out a bit . It's done this twice today . pulled in ,switched off,started up again and its not done since in the last 15 miles home . Had tank up,things seem to look ok under there . Any ideas please :(
  2. Muffking
    My first thought is spark plugs on these.
  3. Selmer50mark
    It was like off on , by the time I thought of WTF it had picked up like nothing had happened , run fine after throughout the rev range ,plugs still original @ 10,100 miles ,had a look around ecu and connections , plugs next if it does it again
  4. Muffking
    I wonder if theses are coming to the age where the plugs start to give trouble as my RR6 track bike was hesitant at high revs last year before the plugs were changed at 13k, a mates low mileage RR4 had to go in for plugs last month, and another members RR4-7 on here needed some new ones recently too. And to top it all my RR5 road bike may need some at 16k as I detected a slight murmur last week which I will be keeping an eye on.
    Still, at least it's only a £50 DIY job. Just a PITA to get to.
  5. Selmer50mark
    Yeah £50 just been pricing some and yes a PITA to get to. Only £24 and 25 mins on my old RRV easy , think I will see what develops over a few runs
  6. Barstewardsquad
    Any error codes? Did the FI display come on?
    You can re-read the errors if you short a couple of wires on the diagnostic plug behind the lh fairing.
  7. Selmer50mark
    No error codes , I didn't see the F1 c'mon, seemed ok after I stopped for ten mins ,
  8. zxrob
    zxrob Active Member
    That kind of problem can be associated with the ignition system
    Firstly, check your battery terminals are tight
    Have you got an immobilizer fitted
    Spark plugs
    There could be a short occurring somewhere
    Rob
  9. Selmer50mark
    Yeah checked batt terminals , generally had a good look for any shorting and bad connections, had thought about alarm/immobilizer it has datatool s4 pain in the arse , hate messing with lectrics o_O
  10. zxrob
    zxrob Active Member
    I had a similar issue with my sp1, turned out to be the immobiliser
    Rob
  11. Selmer50mark
    Cheers Rob ,I will check it out
  12. Selmer50mark
    Update, over 350 miles later and the bike has not missed a beat :confused: wondering if it was a loose connection and while I had the tank up I accadently sorted it . Hope so
  13. PauloHRC
    Glad you're sorted mate!
  14. Selmer50mark
    O bugger its doing it again :( had a hot run, then filtering for 20 mins in standing traffic on M61 , M6 all the way up to M55, ,,,, mainly 1st gear then opened her up and it cut out at 8500 revs then again at 8000 :( hope its just heat soak , temp was around 105
    #14 Selmer50mark, Aug 25, 2019
  15. Iain
    Iain Active Member
    I had similar on my RR4 many years ago, it would not rev above 6k, a new fuel pump sorted it out..
  16. Boothman
    Not done it since 7th May last year until today - wonder if it’s related to ambient temperature? It’s been well warm today and it was that day last year (only remember as its a friends birthday)
  17. Selmer50mark
    It's not a stutter its like flicking the kill switch off n on
  18. Selmer50mark
    Ok it seems be under load when second injectors come in and if i keep the throttle open it feels starved ,:confused::confused:,,,,, anyway got back , up with tank and feed pipe looks like it has a kink in it ,,,,,, let's see if that has been the problem
