Givi Tanklock
Discussion in 'Mods, Upgrades, Accessories and Products' started by Barstewardsquad, May 5, 2018.
  1. Barstewardsquad
    Anyone got any experience of using this system? I'm looking at gettting a new tank bag and was planning on getting a magnetic one but saw this and wondered if it is worth getting.
  2. Muffking
    Garyb used one on the Scotland trip and seemed to get on well with it.
    You just need to remove it when you fill up, although I suppose this is something that you factor in with any tank bag.
  3. SpeedoX
    SpeedoX Active Member
    SW-motech tank ring much better design and quality than Givi, IMHO.
    #3 SpeedoX, May 6, 2018
  4. Kevin1
    Kevin1 Elite Member
    I use the GIVI. I've not had any problems with it, although I did leave it at a petrol station once, oops. If you can just check the size on your bike if you've got a Fireblade. Because of the riding position the larger tanks bags might annoy your stomach area a bit. If you're going on a long trip go medium sized. Day trip ? Get a 5litre
