Indicator Modification
Discussion in 'Mods, Upgrades, Accessories and Products' started by Stan Meadows, May 27, 2018.
  1. Stan Meadows
    Stan Meadows New Member
    I have a 2005 model and will soon be changing my fairings, what I would like to do is replace the front indicators with flush ones and also change the mirrors for ones with built in indicators.
    Has anyone already done this ??? is it straight forward ??? and where is the best place to go for the parts needed ???
    Cheers in Advance.
    Stan
  2. Barstewardsquad
    Simple job as long as you can join wires together. if you want to fit LED ones you will also need to either replace the relay of wire-in some resistors, my preference is replacing the relay.
    Sportsbikeshop, Demon Tweaks and Ebay are a good place to start.
