RR6 Fuel light
Discussion in 'Maintenance' started by Tony Burrell, Jun 24, 2018.
  1. Tony Burrell
    Tony Burrell Active Member
    Hello, I have a fireblade rr6 and
    Is there a way to check if the fuel light is working? Other than running it until the light comes on
    As I'm not too sure if mine is working.
    Thanks Tony
  2. nigelrb
    Other than running a multi-meter check, I'd say if you get to 160 miles with no light, it's not working. At that mileage you still have (based on my experiences with 2004 and 2011) 3 or 4 litres remaining. Mine's usually on at around 150, but others have reported as low as 120.
  3. Tony Burrell
    Well last weekend I went for a blast, and I know there wasn't much fuel in the tank , and I was thinking the light should of came on by now . As the bike wasn't running the same as it did.
    Seem to not get going once I opened her up. But was on it today and seemed spot on.
  4. Selmer50mark
    Depending on how hard you ride as Nige says you might to 160 before it comes on , motorway rides mine comes on about 150, but usually 125 to 130 on back roads. I think you should ride around the garage forecourt till it comes on or you run out ;)
  5. Tony Burrell
    Some people are saying it's meant to come on when you switch the ignition on.
    Is this correct?
  6. Selmer50mark
    No mine doesn't. But does if it was low (RR7 )
  7. Tony Burrell
    That's ok then, might just run it low on fuel and see if it comes on.
    Thanks for all your help
  8. hitch
    hitch Elite Member
    I think I read in Performance Bikes years ago on a fuel test they used to fill up a plastic 5L petrol can, bungee it to the back of the bike then run 'til empty.
    You then haven't got the anxiety of running empty miles away from a garage - simply fill up from the petrol can and off you go.
  9. nigelrb
    Think I might prefer to carry it in a backpack - but I applaud the idea.
  10. Barstewardsquad
    Rather you than me, the thought of having a 5l jerry can on my back and it catching fire, or crashing with it there is not my idea of fun :p
  11. Bikeboy
    Bikeboy Active Member
    Where's your sense of adventure
    • Funny Funny x 3
  12. Tony Burrell
    Hello people, update I disconnected the fuel pump and still no fuel light came on. So had a look at the fuses and there all ok. Wats the next step?
  13. Tony Burrell
    Hello , update I disconnected the fuel pump and still no fuel light came on. So had a look at the fuses and there all ok. Wats the next step?
  14. Selmer50mark
    I dont think disconnecting the pump will make it come on , pump the fuel out of your tank , it should come on at about the last 3 litre As @hitch posted, strap a can on ya bike and go for a long ride , ;)
  15. Bikeboy
    As above.syphon the fuel out. See if the light comes on
  16. nigelrb
    Yep. Most practical advice given.
  17. Tony Burrell
    Another update, I have syphoned the petrol out the fuel light didn't come on dipped the tank had about half an inch of fuel in. So started the engine and left it a minute then the light came on.
    Would that be right for the fuel light to come on when there's only half an inch of fuel in the tank.
    I have taken a picture to roughly show you where the fuel was
  18. nigelrb
    Depending on the angle, that would probably equal about 3 litres, in which case it seeks okay. At least now that you know the light comes on, ride the bike and be prepared around the 130 - 150 mark for the light to come on.
  19. Tony Burrell
    I have got it on the rear paddock stand
    Just doesn't seem a lot.
    How far can you go roughly on reserve
    Thanks Tony
  20. nigelrb
    Depending on riding style, I wouldn't risk more than 25, but if you calculate fuel use per litre, you could get 50, but not worth the risk.
