Wanted old loom 08 onwards
Discussion in 'Parts, Accessories & Clothing' started by Lifeofriley, Aug 12, 2018.
  1. Lifeofriley
    Lifeofriley New Member
    As above has anyone got a old knackered loom they dont want , I'm just after a couple of plugs. Cheers
    J
  2. Lifeofriley
  3. TheMickster
    TheMickster Active Member
    Which plugs you after mate, I’ve got some bits and pieces of the main loom?
  4. Lifeofriley
    Hi pal thanks for your reply. Im after a coil plug with some wire left out of the plug. I believe its for injector 4 not that it matters. My wires dropped into my fan...had a mare.
  5. TheMickster
    Hi Mate
    I'm back home tomorrow so will have a look in the garage, pretty sure i'll have one.
    If it's easy, send me a pic of the one you need.
    Mike
  6. TheMickster
    843C5901-7B07-4008-A994-48F1D2F15A60.jpeg 0A895246-9DC7-4870-B4E9-F960D6685D49.jpeg 73BEF9E2-2FB5-48C1-A885-3DA99BA01351.jpeg Is it this one mate?
  7. Lifeofriley
    Hi mike really sorry for late reply! Hectic couple of days. I will check bike tomorrow to confirm as i cant remeber off the top of my head. Really appreciate this. Joe
  8. Lifeofriley
    Hi mate this is the plug I'm after...ring a bell?
  9. Lifeofriley
    Its part of the coil sub harness.
  10. TheMickster
    Cool, I’ll have a look in the morning mate.
  11. TheMickster
    This looks like the one
  12. TheMickster
    PM me your address mate and I’ll stick it in the post. How much wire do you need left on it?
  13. roboticus
    roboticus Active Member
    hi mick, im after the black plug that connects under the tank if u have it, I pulled mine off then tried to fix it and shagged it up:rolleyes:
  14. TheMickster
    I’ll have a look to see if I’ve got that one.
  15. TheMickster
    Not found this one yet, I assume it will be next to a brown connector on the loom (think there's two wires to the tank?). I'll have a rummage though some of the other boxes of bits. do you know if there's another connector that uses the same plug? if you've got your tank off at the mo send me a pic of it.
    Mike
