As above has anyone got a old knackered loom they dont want , I'm just after a couple of plugs. Cheers J
Hi pal thanks for your reply. Im after a coil plug with some wire left out of the plug. I believe its for injector 4 not that it matters. My wires dropped into my fan...had a mare.
Hi Mate I'm back home tomorrow so will have a look in the garage, pretty sure i'll have one. If it's easy, send me a pic of the one you need. Cheers Mike
Hi mike really sorry for late reply! Hectic couple of days. I will check bike tomorrow to confirm as i cant remeber off the top of my head. Really appreciate this. Joe
hi mick, im after the black plug that connects under the tank if u have it, I pulled mine off then tried to fix it and shagged it up
Not found this one yet, I assume it will be next to a brown connector on the loom (think there's two wires to the tank?). I'll have a rummage though some of the other boxes of bits. do you know if there's another connector that uses the same plug? if you've got your tank off at the mo send me a pic of it. Cheers Mike
