Normal running temperature
Discussion in 'General 1000RR Discussion' started by bradt, Aug 14, 2018.
  1. bradt
    bradt Elite Member
    What's the normal running temperature my rr9 runs between 78-84 is that the norm?
    Fans kick in at 105 ish
  2. Lozzy
    My 16 runs a steady 79 on an open run so yep I'd say it's normal
  3. Wozza
    Wozza Elite Member
    Yep sounds normal to me....my sp in hot weather was at 90... Fan on about 105
  4. Spygoat
    Spygoat Well-Known Member
    Mine runs at about 82 (178F) on a hot day when moving and can hit 105 (220) at a stop..so seems normal!
  5. Bikeboy
    Bikeboy Active Member
    Sounds spot on
  6. PauloHRC
    PauloHRC God Like
    My rr9 is the same......looks like you've got nothing to worry about there @bradt !
    • Friendly Friendly x 1
  7. bonjo
    the figures are good.
    Mine (RR8) run between 76~78 normally. It can go to 80~82 at motorway ++ speeds or very hot days.
  8. bradt
    bradt Elite Member
    So mines about right.
    Thanks for all responses.
  9. Si.
    Totally normal mate
