New Suspension Mod For - CBR1000rr 08-18
Discussion in 'Mods, Upgrades, Accessories and Products' started by vic_ster51, Aug 19, 2018.
  1. vic_ster51
    vic_ster51 Active Member
    New mod for all years CBR1000rr 08-18 abs and non abs. Designed by HRP the german tuning specialist and raceteam.
    Very simple, yet effective modification for your blade on the rear suspension linkage. 4 Teflon washers to make the linkage sit square and work more effective. Stops the connecting dog bone link, rubbing and dragging metal to metal on the triangular plates and main frame mount.
    You CAN'T get these from HRP shipped the UK directly
    Includes -
    4 Teflon Washers
    Fitting instruction sheet - with pictures
    On hand chat support/help
    Postage
    I have added some pics of the said above mod so you can see the before and after results
    PRICING - £30 includes P&P (1st class recorded) to UK - *will post worldwide*
  2. CharlieR85
    £30 for 4 teflon washers. Are you taking the piss mate? This forum is meant to be about helping eachother not ripping them off.
  3. vic_ster51
    It is helping people see a new mod people haven’t seen or can’t get. It is what it is. Don’t want then don’t comment. Go find and get the sizes you need please, oh wait you don’t know! So check your facts First. If you wanted these from hrp which you can’t get into England are €50 plus then sending to uk
    Im making about £5 as includes the time to sort all this, packaging, postage, PayPal fees, the actual items which inc one special made washer which aren’t cheap, full printed instructions etc, my support, my time/fuel to get to post office
    #3 vic_ster51, Aug 19, 2018
  4. nigelrb
    My logical mind makes me wonder WHY these have come into the market. With 10 years of Honda producing Blades (2008 - 18) has there been reported problems with swing arm 'free play' on our bikes? Is anyone aware of recalls for 2008 onwards? Should I be concerned for my own 2008 that I might enter a fast corner and because my swing arm is 'off centre' I'll miss my line?
    Perhaps these 'special made' washers have been specifically manufactured only for race bikes with an already modified swing arm?
    Maybe I should do a trial run with these at 66p each https://www.accu.co.uk/en/flat-wash...X25WuOXcEE_CTDOmMGxwhMc2N19QkR-YaAri4EALw_wcB
    before investing in the authentic product.
  5. roboticus
    roboticus Active Member
    I don't think there for free play, but for the way they pivot better,
  6. CharlieR85
    I could take an educated guess at the size and order 2 sizes above and below what I think they are and it would still be less than £2. You don't need instructions, it's straight forward and I'm not sure what your support would offer for the removal of 1 bolt?
  7. vic_ster51
    Not sure if ones you found are the same as mine high spec teflon washers and you need exact sizing. As something going wrong with your suspension is never a good thought. These spec'ed as per the place that produces parts and racebikes etc. So tried and tested thus no problems.
    Also found this after a quick search... so there has been few problems of this. This 1 area people dont check or notice often.
    https://www.1000rr.co.uk/threads/creaking-clicking-pinging-rear-shock.20857/
  8. CharlieR85
    You could even fabricate your own with a small teflon sheet. It's not as if they need to be pretty.
  9. CharlieR85
    Mate I don't really care actually. Sheep are for shearing, good luck to yourself.
  10. vic_ster51
    Well yes true, nothing stopping you, but mine already made to fit, not guessing and thus no problems with the movement in the linkage.
    2 bolts :p... and abit of work needed actually, supporting the bike off the ground, exhaust off etc. Lots people cant do basic stuff
    Well now you know your way of doing it... so you found new mod you can do yourself. Happy days.
  11. CharlieR85
    Why don't you just measure up your magic bean washers from this German outfit and order a batch of equivellant from a website like Nigel suggested for pennies and carry on charging £30? You would change your profit from £5 to £27. That is how to properly rip people off my friend.
  12. CharlieR85
    Or maybe you've already thought of this? o_O
  13. vic_ster51
    I thought you didn't care? I have done my research and pricing and again 1 washer is specially made and others aren't pennies, plus other costs. But you no best. Now go watch them sheep shearing themselves in your world
  14. nigelrb
    Now come on Charlie. We all know that competitive consumer demand will be satisfied by 'value adding' the product.
    There is a multitude of support that would be applicable (and possibly appreciated) for this (complex for some) operation. for instance:
    • preparation of clean work area
    • adequate lighting
    • appropriate socket size
    • reference to manual for specified torque
    • hire/purchase of torque wrench
  15. CharlieR85
    Oops sorry, yes I don't care. Enjoy.
  16. si1000repsol
    There has always been issues with play on the 08 plus on race bikes. This is to do with the design using roller bearings and not the lack of washers!
    I have the Factory HRC swingarm and the fittings are interchangable with stock (and will fit on the 17/18 bike) so suffers the same issues as a stock bike.
    There is some side play but does not impact the handling and indeed causes some wear on the dogbone and plates.
    These washers will stop wear on these components (linkages can be sourced on ebay for £20 used but doubt it would come to that)
    This personally should be 'low cost' mod that should be shared openly as a 'how to' and for less inclined an option to buy his washers rather than solely for profit.
    Also HRP do ship to the UK as I have had many parts off them but you have to email them first (Should you want to fork out £50!)
  17. tuktuk
    tuktuk Elite Member
    Is that this kind of swingarm?
    How do you get hold of these? I ha e a factory akra system which runs really close to the stock swinger, ideally need one of these type.
  18. si1000repsol
    No mate mine is the ones used in BSB and TT. I have the same exhaust and yes its quite close
    #18 si1000repsol, Aug 19, 2018
  19. roboticus
    si1000repel, I've some padgents rearset, look sim to yours have u got yours wired to the rear brake light?
  20. si1000repsol
    No mate but have a hydraulic brake switch to fit that replaces the banjo if I need to wire it in.
