Kev's SP1 not a happy chappy
Discussion in 'General 1000RR Discussion' started by Kevin1, Sep 17, 2018.
  1. dgr
    dgr Active Member
    From the research I have done and from my own experience, an ECU remap is a huge improvement. I don't think you have to 'learn to accept it'.
  2. Kevin1
    Kevin1 Elite Member
    Do they remap all the modes or just one?
  3. dgr
    dgr Active Member
    All of them, I believe, for fuelling at least. The different modes effectively just adjust throttle response and in some cases limit maximum power in certain gears, as I understand it. The guys that did mine used Mode 4 to map a 1:1 throttle response to use if you like a more linear throttle.
    #23 dgr, Sep 18, 2018
  4. Kevin1
    Kevin1 Elite Member
    Who did this remapping for you?
  5. dgr
    dgr Active Member
    BSD Performance near Peterborough. From my own experience I would recommend them. I'm led to believe that some of the bike mags take their bikes there to be mapped.
    Their website is here, http://bsd.uk.com/, and they are on Facebook too.
  6. Kevin1
    Kevin1 Elite Member
    Just taken it out for a play. Disconnecting battery didn't make any difference but it was worth a shot.
  7. Wozza
    Wozza Elite Member
    I must be lucky no issues on mine 2018... Left it on standard can....when I rode the 2017 demo it had a yoshi on it and that was jerky.....so pulled out of the Akro that I had ordered it only give 1bhp more at 12k revs...as for the modes I notice a big difference between each and no numb hands etc...,the loop I do is 110 miles so it gets a good work out....
  8. Kevin1
    Kevin1 Elite Member
    The exhaust is not part of the equation. It was doing it before the exhaust was fitted. I'll probably have to pay out more money to get the ECU mapped. Not, so it can pass EU regs, so it can pass a bus at 30 mph. :)
  9. Kevin1
    Kevin1 Elite Member
    What did you have before the SP @Wozza ?
  10. nigelrb
    Shit! Now I really gotta do something about my 30-miler:rolleyes::).
    Cotswolds has some good roads, but many are akin to farmers' back roads.
  11. Mattie660
    Mattie660 Elite Member
    Sorry to hear that you are having grief with your new bike. I had similar with the GSX-S but knew about it (mostly) before buying it.
    Is a Power Commander (or similar) not up to the job of sorting out the fuelling ?
  12. nigelrb
    Probably would be but heck of an expense on a new bike that should be running right from the start!;)
  13. dessp2
    dessp2 Well-Known Member
    The concept of Honda is ‘we’ build road bikes that go on the track, not the other way around. Has that concept gone out of the window in order to keep up with their rivals? I am still in awe of my 2012. No fly by wire, no traction control, no modes, no ABS or any of that ball axe.
    • Like Like x 7
  14. gcon45
    gcon45 Active Member
    I know you had a problem before the exhaust was fitted but if you didn't reset the ECU before and after fitting the exhaust your fuelling will be all over the place for a few tanks at least.
    I reset my 2018 ECU when receiving a faulty servo buddy the same way as the older bikes and it worked.
    Warning lights cleared and rides like a dream. I must be one of the lucky few who likes the fly by wire throttle connection.
    I've had it on an Africa Twin Adventure Sports and now on a 2018 SP1 and the connection is amazing on both.
  15. Kevin1
    Kevin1 Elite Member
    Exhaust was fitted by the dealer that supplied the bike. I'm assuming they did all the necessary adjustments.
    How did you reset your ECU?
  16. gcon45
    1. Disconnect the battery for 10 mins then reconnect
    2. Turn engine on with no throttle input
    3. Allow engine to idle until fan comes on
    4. Switch engine off with kill switch
    5. Remove key
    #36 gcon45, Sep 18, 2018
  17. gcon45
    Sorry - had to edit to add step 1!
  18. gary1966
    gary1966 Active Member
    Is this a known set up and does it really work?
  19. gary1966
    I went from akrapovic can to standard the throttle response at slow speed is 90% better but when wacking it open it was very stop start but I think this got better as the day went on, so perhaps the ecu has sorted it out by its self? After taking the akrapovic off I kept the servo buddy and just removed the cables from the standard can.
  20. Barstewardsquad
    Has been standard for some years now. Used it on my RR7.
