Comfort gel seat 2008-16 SOLD
Discussion in 'Parts, Accessories & Clothing' started by Nigelg79, Oct 21, 2018.
  1. Nigelg79
    Nigelg79 Active Member
    3B830AE5-4525-4672-9B25-7016360A7446.jpeg F11652AB-C3FA-474B-8EF2-DB40634E4B9A.jpeg A93C087B-E415-4EA4-8AC1-CB85B13A00BB.jpeg Getting ready to sell the blade so taken the extras off to sell separately.
    First up, the Genuine Honda comfort seat. I think it fits 2008-16 models.
    In very good condition, one tiny nick in it which doesn’t affect performance. So comfortable over the original seat!
    £100 plus postage.
    #1 Nigelg79, Oct 21, 2018
  2. Nigelg79
  3. Cbrjay
    Cbrjay Well-Known Member
    Cheap enough that mate
  4. Fwsock
    Fwsock Active Member
    Do you need an original seat to replace it with. I’ve got a brand new one still in box. Could swap?
  5. BadboyRepsol
    BadboyRepsol New Member
    Hi how do you place an advert on here ?
  6. Cbrjay
    Great 1st post
  7. BadboyRepsol
    I'm looking for a pillion seat for an 09 blade the 08 won't fit my blade as won't any that are advertising 08 onwards
  8. Cbrjay
  9. Fwsock
    Should do, don’t think the pillion pad changed at all from 08-16. Is there something under your seat fouling it?
  10. BadboyRepsol
    No nothing under the seat I bought a seat off eBay I've added a photo it was advertised for an 08 / 14 but you can see it clearly doesn't fit it locks in but the back doesn't fit it's supposed to have 2 little lungs on the end like my seat cowl but just has the fat 1in the middle all on EBay are the same fitting as the one they sent me
  11. vic_ster51
    vic_ster51 Active Member
    It will fit! You have chinese items. Seats all the same 08-16 you put the rear section hook in first. It might be tight especially if its not OEM but its correct item either way
  12. Lozzy
    The pillion 'seats' are much tighter fitting than the aftermarket cowls. Like Vic said it just needs the hook in first and then a good shove.
  13. Fwsock
    That’s def the correct seat. Just give a good shove in at the rear before clicking the front in.
