magnetic sump anyone?
Discussion in 'Maintenance' started by bonjo, Nov 5, 2018.
  1. bonjo
    anybody has or is using one?
    pros & cons please
  2. hitch
    hitch Elite Member
    Don't they stick a magnet or two in the sump to catch 'bits' anyway?
  3. nigelrb
    Back in my 'CB' days, all the sump plugs (Honda at least) were magnetised. Isn't that still the case?
  4. hitch
    hitch Elite Member
  5. hitch
    hitch Elite Member
  6. nigelrb
  7. Jez
    I always fit magnets to sump plugs, cars or bikes, I have not had had anything worrying on the cbr, but it is a bit like fishing, When you change your oil you always wonder if you have caught something, only difference is if you have got a big lump it is worrying,
  8. MPB
    MPB Active Member
    They are good to stop some of the particles going around the engine, but a worry is that if the magnet was to work its way loose it would cause more damage than it prevents.
    Ive used them on other bikes with no issues.
  9. Jez
    I must admit that thought has crossed my mind, I machine mine out on the lathe and make them a push fit in
