SP Tail Tidy Recommendations?
Discussion in 'General 1000RR Discussion' started by PauloHRC, Jan 2, 2019.
  1. Kevin1
    Kevin1 Elite Member
    You'll have to cut the wires to the tail light if you want to use the original connector by the looks of things. I don't think I've found a TT yet that supplies an original tail light connector.
  2. PauloHRC
    I know what you mean, why can't they fit a honda connector?? I'm going to fit the light but not connect it up. You only need it for MOT dont you and that's 3 years away!
    Doubt I'll be riding at nighto_O
  3. nigelrb
    By which time you'll have a 2020 model and @Lozzy will have your SP.:D
    • Optimistic Optimistic x 1
  4. Ravsta
    Ravsta Active Member
    Looks solid as you say. Looking fwd to seeing it on the bike. I'll be ordering mine on the weekend :)
  5. Ravsta
  6. Lozzy
    Unless you get lost :rolleyes:....which is a distinct possibility :D
  7. PauloHRC
    Attempted to remove the pig ugly number plate hanger today, looked simple enough but it's a bit tight in there!
    Trying to get a spanner on them bolts is harder than it looks. Does anyone have any advice on this, any body work need removing from the tail end??
  8. Kevin1
    Kevin1 Elite Member
    Take a look at this.
    It's a bit slow but it is step by step. There is a little hiccup in the middle but it's worth a watch.
    • Useful Useful x 2
  9. PauloHRC
    Thanks @Kevin1 ......a lot more involved than I thought, will give it another go tomorrow!
  10. nigelrb
    Good find, Kevin. I glanced through it - I didn't realise the job is so involved!
    That'll help Paul tremendously!
  11. fusspot07
    fusspot07 Active Member
    Following as was looking these tail tidies myself
  12. nigelrb
    I reckon they're essential for any Blade!! Improves the looks 100%.
    If I was in New Zealand I'd say that a Blade without a tail tidy looks like a sheep with dags hanging out of its backside!:)
  13. PauloHRC
    Little update on the tail tidy installation, half way through it now thanks to the video @Kevin1 uploaded. Alot of pausing and playing but it has been easy enough to follow.
    Decided not to connect the LED number plate light. It's fitted but didn't want to cut the connectors off. Will just route the wires through as normal out of sight. I wonder if there is a mini solar panel available you could connect the two bullet connections too and stick it somewhere out of sight but where it'll get a bit of sun??:rolleyes:
    Will post more pics when finished:)
  14. nigelrb
    Doin' well Paul. All worth it in the end!
    Blame modern times. Back in the 'olden days' many of us remember, we take the tank off a bike and all that's underneath is a set of coils with leads to the plugs. Take off the seat and there's a battery and a flasher can and rectifier if we're lucky. Take off the 'chrome':) rear guard/fender and you have one wire with three connectors to indicators and tail light. End of story.
    Today, a petrol isn't even a friggin' petrol tank; a coil is better known as a contraceptive device; and a flasher can is a suspect guy in an overcoat in the council toilets. So where'd this friggin' LED, ECU, TFT, injection, etc come from? Friggin' progress:rolleyes:;).
  15. fusspot07
    looking good i saw these on ebay and thought that seems a good deal but was unsure how the quality would be
  16. nigelrb
    You can be sure Paul wouldn't put it on his bike if it were crap!! Best of all, 30 quid cheaper than R & G!.
  17. PauloHRC
    All done, fit was perfect and tail tidy itself is solid in construction, highly recommended! Opened the back end up nicely;) quite easy to work on really but like most things it seems impossible without a little video guidance. One thing this job has highlighted, is how good the paint work is on this bike, up close it really is a stunning finish!:)
  18. PauloHRC
    • Like Like x 6
  19. Selmer50mark
    That look a lot better , it a shame that manufacturers have their hands tied with stupid legislation like number plate hangers , even fork reflectors spoil the look o_O are they coming off Paul?
  20. fusspot07
    bloody nice job dude !
