Radiator over flow hose.
Discussion in 'General 1000RR Discussion' started by Lifeofriley, Jan 12, 2019.
  1. Lifeofriley
    Lifeofriley New Member
    Hi gents I'm moving my overflow bottle to the front ie HRC ones. Can someone recommend where to get the breather hoses and over flow hoses from? What size do I need? Thanks.
  2. nigelrb
    Surely you have to match the hose to the fittings?
    I'd go to B & Q. They have a range of sizes. I've purchased there before for brake bleeding tube.
  3. Lifeofriley
    That's correct this is a fire blade forum so was hoping someone would know the size so I can pruchase off the internet. But I will try b&q thanks Nigel
  4. Bikerznod
    Bikerznod New Member
    From help on another thread i was informed it was 6mm internal diameter, i found loads on ebay
  5. Lifeofriley
    That's awesome thanks pal.
  6. nozdog
    nozdog Active Member
    The clear pipe I used is 6mm Internal and 9mm external diameter 3m in length will be more than enough you need. Try eBay.
    Taken from another post
