Crash bungs(track bike)
Discussion in 'General 1000RR Discussion' started by Lifeofriley, Jan 28, 2019.
  1. Lifeofriley
    Lifeofriley New Member
    What are you track Day riders using for crash bungs. Obviously nothing to intrusive.
  2. PauloHRC
    I don't put myself in the category of 'Track day rider' but I do the odd track day throughout the year. Regarding crash bungs, I would be more inclined to go down the route of engine case covers, GB Racings one's in particular and couple them with some track fairings or after market road fairings.
    My philosophy on this is that the bike is more likely to slide on the fairings and engine covers and come to a stop somewhere down the road or on the grass or gravel trap. I did this with my 09 blade which I've just traded in and intend to do with my new bike.
    With crash bungs, you hear all sorts of stories about them digging in and barrel rolling the bike causing untold amounts of damage. This has never happened to me...... but you can see, by the way crash bungs protrude, why this would happen. Plus I don't like the look of them! ;)
  3. Lifeofriley
    Hi mate I appreciate your feedback. I have GB covers etc and don't usually run crash bungs, im just a little concerned as I go to Jerez soon and fear that if I have a spill I don't fancy trying to source a crank cover etc. Ideally I want track designed sliders.
  4. roboticus
    roboticus Active Member
    i'v dropped bike with sliders on, only slow speed though, and they defiantly do a job, it ground half way down, i'v never dropped it with just the gb covers on,
  5. Jae
    Jae Active Member
    I'm running Ozy Knobs sliders, GB Racing engine covers and R&G fork sliders
  6. KPH
    KPH Active Member
    I use R&G axle sliders on the front & rear, engine case covers and the frame sliders
  7. Lifeofriley
    Cheers for the feedback lads. Going to go for GB bullet sliders and r&g axel bobbins.@KPH that's a stunning blade, what can you running?
  8. KPH
    KPH Active Member
    Cheers, its an Arrow Ti full system that I bought from Lee Hardy racing when they were riding Hondas in BSB.
  9. Singh1000RR
    Singh1000RR Active Member
    R&G - if you crash they typically swap them for free if you give them a good write up on Social Media
  10. Lifeofriley
    Tasty mate. Do you run without a baffle? I'm looking to loose the side can as I keep getting black flagged at Donny.
  11. Lifeofriley
    That's handy to know. Tried this yourself?
  12. Singh1000RR
    Yes. Went down on one side and a guy at the track told me. I emailed r&g and they said thry’d Replace the single bung if I gave them a positive post on social media.
    But sshhh keep it on the down low
  13. PauloHRC
    So......if it's on the down low, I take it it's not officially in R&G terms and conditions, that they will actually do this then??o_O
    Sounds like you just got lucky pal :D
  14. Singh1000RR
    True. It’s not in their T&C’s so they are not obliged to do this but the guy who told me got it, I tried it and got it .... maybe it’s how you ask.
  15. grip-wolrd
    grip-wolrd Active Member
    I have R&G covers and no crash bungs.
    I am worried about the frame structure and engine case with crash bungs as I've heard stories of curbs and edges ripping the crash bung and bending frames/cracking cases. This could be fear mongering but its not worth it to me.
    Let the bike slide, fairings are cheap.
  16. Singh1000RR
    I'm no trackday expert, only done < 10 but what I have seen there are two types of crashes on a track day
    minor slides (typically done by novices)
    fookin massive end over ends (typically done by "experts")
    bungs will save a lot of damage in minor slides. However no end of engine cases, sliders, etc will save the bike in an end over end.....
    just my opinion
